What am I missing with my setup?
Benjamin
With my setup I'm trying to use Transmission, then use plex to stream to my TV's. Also using it to use software across the network.
I installed 9.2.1.5 on to my flash drive.
  • Setup static IP 192.168.1.150/24 IPv4
  • Login to web gui
  • Setup password for root
  • Setup network info
    • DNS - 192.168.1.1, 8.8.8.8, 8.8.4.4
    • Gateway - 192.168.1.1
  • General info
    • Time zone: EST
  • Storage* same name
    • 5x 3TB RaidZ (10.41TB)
      • 1 Dataset called "locker"
    • Storage permissions are set to owner:nobody group:nogroup - I trust everyone in the network since it's only my wife and I.
  • Share (CIFS)
    • share permissions same as storage
    • /mnt/storage/locker/
  • Plugins (transmission)
    • 192.168.1.152
    • /mnt/storage/locker/torrents *same permissions*
  • Plugins (plex)
    • 192.168.1.154
    • /mnt/storage/locker/plex, /movies, /music, /apps/windows, /apps/mac
When I try using transmission it says i don't have permission, same with plex.
Thanks in advance
krikboh
Are your jails installed inside the locker dataset or in their own dataset in the storage pool? I believe the plugins need to be installed in a dataset with root and wheel ownership.
Benjamin
They are installed using the "installer" so I think this is the setup.
  • Storage
    • locker
  • transmission_1-jail
  • plex_1-jail
krikboh
In the Jails configuration tab you can set the Jails root to any location, but if you did not change it I believe it defaults to the root of your pool so that would be correct. I'm no permissions expert and the only other suggestion I could make would be to setup your anonymous access using a guest account as the manual suggests, not using nobody/nogroup. This is how my system is setup and working well.
Benjamin
Thanks for your help I'll try again today. No more upgrading for me I did have everything working when installed 9.2 upgrading to 9.2.1.2 broke my permissions.
