Has anybody tested this news drives in a system?. I´m thinking in buying six of them and, at this moment, it seems nobody has tested it... I suppose the use of "wdidle" is still mandatory. Am I right?
They should be similar to the old ones. Wdidle may not work with newer Greens, but those reports are unconfirmed at the moment. Reds would not need wdidle.
I'm using WD Reds which do not need the wdidle tool. The Green 6TB drives didn't exist when I bought my Reds (I bought mine the day they went for sale on Newegg).
Yeah, the warnings about 2TB is entirely relative. There's simple statistical math that will tell you "if a given config" is a good idea or not. For my situation I found the odds of data loss for *my* setup to be low enough to feel comfortable with it. Ultimately any thumbrule that specifies disk sizes limits is garbage because the statistics are really what you need to look at.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
