Hello. I have an array of 12 disks. 8 are 1TB and 4 are 2TB. I am slowly replacing the 1TBs with 2TBs as they fail. I had a 1TB fail yesterday so I do the normal thing to replace it. Pop the drive (hot swappable chassis), verify the serial number, insert new drive, reboot FreeNAS, and click replace disk. It took about 24 hours to resilver then everything seemed fine. The critical error went away, disk speeds returned to normal, etc. After about 10 min, I get a notification that there is an error. I assumed it was invailid but I double checked FreeNAS and there is a new error:
The volume Storage state is ONLINE: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
The only this I noticed that is unusual is that the new disk has a 103 under Checksum and is climbing in the Volume Status. After an hour or so the disk went to DEGRADED. This is a brand new disk I opened before installing. I pulled the drive out of the system and CDI says it's fine. The other thing I tried was smartctl from the FreeNAS web shell but I could only get
Read Device Identity failed: Inappropriate ioctl for device
After an hour or so the disk went to DEGRADED. This is my first build of FreeNAS and the company that hosts my backup server said that it suffered a double disk failure losing my backup so I'm not looking to chance anything at the moment. Thanks in advance.
