Boot replacement problem
ghostguy
I'm a pretty green FreeNAS user and have a problem I don't know how to fix.
I have my Freenas 11.1.u7 on a 32GB Scandisk flash drive. Recently it degraded, so I set out to replace the USB drive. I bought a new 128GB ScanDisk thumb drive.
I followed instructions to mirror the boot pool and add the drive. It shows the new USB as da1 and online. The old USB is da0 and shows degraded.
When I click replace da0. there is NO disk in the "member" drop-down to choose from. ( assuming I did this correctly)
When I pull the da0 (old USB) from my motherboard and try to boot from the new boot pool da1, it stops every time at "Syncing Disk". and has never gotten past that.
When I plug the old USB da0 back in, FreeNAS boots up fully and everything works as normal still listing as da0 degraded and da1 online
HELP?!?!?
Thanks
Samuel Tai
What does zpool status -v freenas-boot show? I'm curious if you actually correctly mirrored da0 to da1.
Samuel Tai
In the GUI, click the Shell menu on the left. Once it comes up, type that command into the prompt.
ghostguy
da0p2 DEGRADED 0 0 166 too many errors
da1p2 ONLINE 0 0 162
//usr/local/sbin/pkg-static
//usr/local/sbin/resize2fs
//usr/local/sbin/smartctl
//usr/local/sbin/storcli
//usr/local/sbin/tcsd_emu
//usr/local/www/dojo/dojo/cldr/nls/ar/buddhist.js
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/sbin/dnssec-revoke
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/go/src/runtime/asm_amd64.s
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/go/src/runtime/defs_linux_ppc64.go
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/sbin/dnssec-settime
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/lib/samba/libsmbd-base-samba4.so
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/sbin/dnssec-signzone
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/lib/shared-modules/pdb/ldapsam.so
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/www/dojo/dojo/cldr/nls/fi/generic.js
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/sbin/grub-install
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/libexec/git-core/git-http-backend
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/go/pkg/tool/freebsd_amd64/doc
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/libexec/git-core/git-http-push
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/go/pkg/tool/freebsd_amd64/link
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/go/pkg/tool/freebsd_amd64/nm
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/go/pkg/tool/freebsd_amd64/pack
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/go/pkg/tool/freebsd_amd64/pprof
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/share/fonts/dejavu/DejaVuSans-Bold.ttf
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/share/fonts/dejavu/DejaVuSans-BoldOblique.ttf
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/share/fonts/dejavu/DejaVuSans-Oblique.ttf
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/share/fonts/dejavu/DejaVuSansCondensed-Bold.ttf
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/lib/sasl2/libscram.so.3.0.0
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/sbin/iprop-log
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/libexec/git-core/git-remote-https
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/share/man/man1/expand.1.gz
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/go/src/runtime/race/race_darwin_amd64.syso
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/sbin/pkg-static
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/share/info/heimdal.info.gz
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/go/src/runtime/race/race_windows_amd64.syso
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/lib/samba/libgensec-samba4.so
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/lib/shared-modules/ldb/dirsync.so
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/go/src/cmd/vendor/golang.org/x/arch/arm/armasm/tables.go
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/sbin/smartctl
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/go/src/regexp/syntax/simplify_test.go
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/www/dojo/dijit/form/_ComboBoxMenu.js.uncompressed.js
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/lib/samba/libsamba-net-samba4.so
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/lib/samba/libsamdb-common-samba4.so
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/sbin/dnssec-dsfromkey
freenas-boot/ROOT/11.1-U7@2018-05-06-21:06:05:/usr/local/go/src/runtime/type.go
[root@freenas ~]#
Samuel Tai
Ok, so you do have a mirror, but both thumb drives are showing checksum errors, which is why the newer drive won't boot. You'll need 3 more thumb drives.
  1. First, under System->General, use the "Save Config" button to save your config to one of the new thumb drives.
  2. Next, burn the installer to the second of your new thumb drives. You can find the ISO for 11.1-U7 at https://download.freenas.org/11/11.1-U7/x64/FreeNAS-11.1-U7.iso.
  3. Reinstall FreeNAS to the 3rd new thumb drive.
  4. Reboot off the new thumb drive. After the system has finished booting, navigate to System->General, and click "Upload Config" to restore your config from the first thumb drive.
  5. Reboot again, and your pool should import. Your system should be back in business.
ghostguy
ok, great I'm planning that today.
here we go. Thanks again
