Hello all,
I have installed Jellyfin as an app in TrueNas Scale. At first everything seemed to work smoothly. My server (A) sends the video to my browser (B), or my FireTVStick (F) as requested...but!!!!!!!!! When I shut down B or F and later want to access Jellyfin again, it does not work. The Jellyfin login page (which shows me that Jellyfin is online) tells me there is no connection to the server...okay. Try again...no connection. The only way to get back on Jellyfin as a user is to restart server A. However, when I restart the server I have to re-register with Jellyfin and re-assign the folders with the media. The previously registered user is just gone. And this happens again and again and again. Somehow Jellyfin does not save the created user and/or blocks any new attempt to reconnect to it. So of course you can't use the actually great system at all.
Does anyone have an idea what this could be due to?
EDIT: SOLVED there was an error with using my own host pathes. I installed it with ixVolume and everything works as it should.
