WebUI session timeout
telenoar
Hi, I'm on FreeNAS 11.1.
Yesterday I ran some admin work in the web GUI, closed the tab... and 16 hours later discovered that I didn't need to re-authenticate.
How can I change that, so the session would expire after X time or tab-closure?
Didn't find a setting for it in the UI.
I dug around... searching brought up one old answer about a "session.php" file that I couldn't locate. And I found a "SESSION_EXPIRE_AT_BROWSER_CLOSE" setting in /usr/local/lib/python3.6/site-packages/django/conf, but I don't call myself a linux expert and not familiar with django, so I may be looking in the totally wrong place.
Thanks
JV9
TrueNAS Core - TrueNAS-12.0-U5
I have the same question, but the opposite problem: the default timeout is WAY too short when you're setting up the system and bouncing between jails, vms, and the truenas gui.
I'd like to be able to increase it to say 1 hour while I do the setup, and then drop it back to something more secure & reasonable like 5 minutes.
I can't find any documentation on this, or any setting via the GUI. This seems like something that should live on the System>General tab.
If anyone has insight on where I can make the change and have it stick across reboots, I'd be very grateful.
JV9
listhor
I can see that nothing has been changed since above posts were published. It annoys me as well. Is there any way to change session timeout?
paradoxiom
Ah, I guess my google search ends here then.
majorgear
+1 for session timeout configuration because only the user knows their security requirements, vendors can suggest settings but they should never try to second-guess what the end user needs. One size does not fit all.
Redcoat
Go to the Jira link in post #3 above and add your vote there.
