SOLVED After Reboot "MIDDLEWARED FAILED TO START"
gr4ni
Hey, guys,
I don't know what to do here. I have the following problem: After a restart the Web-GUI didn't work anymore:
"Connecting to NAS... Make sure the NAS system is powered on and connected to the network. "
SSH connection's still working, so I took a look at what's going on with "dmesg -a".
That's the output:
Copyright (c) 1992-2018 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
    The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 11.2-STABLE #0 r325575+9a3c7d8b53f(HEAD): Wed Mar 27 12:41:58 EDT 2019
    root@mp20.tn.ixsystems.com:/freenas-releng/freenas/_BE/objs/freenas-releng/freenas/_BE/os/sys/FreeNAS.amd64 amd64
FreeBSD clang version 6.0.0 (tags/RELEASE_600/final 326565) (based on LLVM 6.0.0)
VT(vga): resolution 640x480
CPU: Intel(R) Pentium(R) CPU J4205 @ 1.50GHz (1497.66-MHz K8-class CPU)
  Origin="GenuineIntel"  Id=0x506c9  Family=0x6  Model=0x5c  Stepping=9
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x4ff8ebbf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,SDBG,CX16,xTPR,PDCM,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,RDRAND>
  AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
  AMD Features2=0x101<LAHF,Prefetch>
  Structured Extended Features=0x2294e283<FSGSBASE,TSCADJ,SMEP,ERMS,NFPUSG,MPX,PQE,RDSEED,SMAP,CLFLUSHOPT,PROCTRACE,SHA>
  Structured Extended Features3=0x2c000000<IBPB,STIBP,ARCH_CAP>
  XSAVE Features=0xf<XSAVEOPT,XSAVEC,XINUSE,XSAVES>
  IA32_ARCH_CAPS=0x1<RDCL_NO>
  VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID,VID,PostIntr
  TSC: P-state invariant, performance statistics
real memory  = 8589934592 (8192 MB)
avail memory = 7865364480 (7500 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <INTEL  EDK2    >
WARNING: L1 data cache covers less APIC IDs than a core
0 < 1
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 2.0> irqs 0-119 on motherboard
SMP: AP CPU #2 Launched!
SMP: AP CPU #1 Launched!
SMP: AP CPU #3 Launched!
Timecounter "TSC" frequency 1497660922 Hz quality 1000
random: entropy device external interface
random: registering fast source Intel Secure Key RNG
random: fast provider: "Intel Secure Key RNG"
kbd1 at kbdmux0
nexus0
cryptosoft0: <software crypto> on motherboard
aesni0: <AES-CBC,AES-XTS,AES-GCM,AES-ICM> on motherboard
padlock0: No ACE support.
acpi0: <ALASKA A M I > on motherboard
unknown: I/O range not supported
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x77 on acpi0
atrtc0: Warning: Couldn't map I/O.
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff irq 8 on acpi0
Timecounter "HPET" frequency 19200000 Hz quality 950
Event timer "HPET" frequency 19200000 Hz quality 550
Event timer "HPET1" frequency 19200000 Hz quality 440
Event timer "HPET2" frequency 19200000 Hz quality 440
Event timer "HPET3" frequency 19200000 Hz quality 440
Event timer "HPET4" frequency 19200000 Hz quality 440
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <32-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
vgapci0: <VGA-compatible display> port 0xf000-0xf03f mem 0x90000000-0x90ffffff,0x80000000-0x8fffffff at device 2.0 on pci0
vgapci0: Boot video device
pci0: <multimedia, HDA> at device 14.0 (no driver attached)
pci0: <simple comms> at device 15.0 (no driver attached)
ahci0: <AHCI SATA controller> port 0xf090-0xf097,0xf080-0xf083,0xf060-0xf07f mem 0x91314000-0x91315fff,0x91318000-0x913180ff,0x91317000-0x913177ff at device 18.0 on pci0
ahci0: AHCI v1.31 with 2 6Gbps ports, Port Multiplier supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
pcib1: <ACPI PCI-PCI bridge> at device 19.0 on pci0
pci1: <ACPI PCI bus> on pcib1
re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xe000-0xe0ff mem 0x91204000-0x91204fff,0x91200000-0x91203fff at device 0.0 on pci1
re0: Using 1 MSI-X message
re0: Chip rev. 0x4c000000
re0: MAC rev. 0x00000000
miibus0: <MII bus> on re0
rgephy0: <RTL8251 1000BASE-T media interface> PHY 1 on miibus0
rgephy0:  none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Using defaults for TSO: 65518/35/2048
re0: Ethernet address: 70:85:c2:82:30:a2
pcib2: <ACPI PCI-PCI bridge> at device 19.1 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> at device 19.2 on pci0
pci3: <ACPI PCI bus> on pcib3
ahci1: <ASMedia ASM1062 AHCI SATA controller> port 0xd050-0xd057,0xd040-0xd043,0xd030-0xd037,0xd020-0xd023,0xd000-0xd01f mem 0x91100000-0x911001ff at device 0.0 on pci3
ahci1: AHCI v1.20 with 2 6Gbps ports, Port Multiplier supported
ahci1: quirks=0xc00000<NOCCS,NOAUX>
ahcich2: <AHCI channel> at channel 0 on ahci1
ahcich3: <AHCI channel> at channel 1 on ahci1
pcib4: <ACPI PCI-PCI bridge> at device 19.3 on pci0
pci4: <ACPI PCI bus> on pcib4
xhci0: <Intel Apollo Lake USB 3.0 controller> mem 0x91300000-0x9130ffff irq 17 at device 21.0 on pci0
xhci0: 32 bytes context size, 64-bit DMA
usbus0 on xhci0
usbus0: 5.0Gbps Super Speed USB v3.0
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
acpi_button0: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart0: console (115200,n,8,1)
wbwd0: <Nuvoton NCT6793 (0xd1/0x21) Watchdog Timer> at port 0x2e-0x2f on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
Timecounters tick every 1.000 msec
freenas_sysctl: adding account.
freenas_sysctl: adding directoryservice.
freenas_sysctl: adding middlewared.
freenas_sysctl: adding network.
freenas_sysctl: adding services.
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
ugen0.1: <0x8086 XHCI root HUB> at usbus0
uhub0: <0x8086 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
uhub0: 15 ports with 15 removable, self powered
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD20EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device
ada0: Serial Number WD-WCC4M2ZHVL3L
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors)
ada0: quirks=0x1<4K>
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <WDC WD20EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device
ada1: Serial Number WD-WCC4M5JHPNKX
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors)
ada1: quirks=0x1<4K>
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <WDC WDS120G2G0A-00JH30 UE500000> ACS-2 ATA SATA 3.x device
ada2: Serial Number 190736806960
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 512bytes)
ada2: Command Queueing enabled
ada2: 114480MB (234455040 512 byte sectors)
random: unblocking device.
Trying to mount root from zfs:freenas-boot/ROOT/default []...
<118>middlewared: starting                                       middlewared: loading plugins                                middlewared: loaded plugin sysdataset                       middlewared: loaded plugin __init__                         middlewared: loaded plugin smart                            middlewared: loaded plugin webdav                           middlewared: loaded plugin etc                              middlewared: loaded plugin filesystem                       middlewared: loaded plugin network                          middlewared: loaded plugin s3                               middlewared: loaded plugin domain_controller                Middleware startup is idle for more than 240 seconds
MIDDLEWARED FAILED TO START, SYSTEM WILL NOT BEHAVE CORRECTLY!
Loading early kernel modules:
Syncing disks...
Failed to run middleware call. Daemon not running?
Setting hostuuid: a722a1d7-5cad-11e9-bb9a-7085c28230a2.
Setting hostid: 0x4ec79acf.
Starting file system checks:
Mounting local filesystems:.
  File "/usr/local/bin/autotune", line 29, in <module>
    django.setup()
  File "/usr/local/lib/python3.6/site-packages/django/__init__.py", line 22, in setup
    configure_logging(settings.LOGGING_CONFIG, settings.LOGGING)
  File "/usr/local/lib/python3.6/site-packages/django/conf/__init__.py", line 53, in __getattr__
    self._setup(name)
  File "/usr/local/lib/python3.6/site-packages/django/conf/__init__.py", line 41, in _setup
    self._wrapped = Settings(settings_module)
  File "/usr/local/lib/python3.6/site-packages/django/conf/__init__.py", line 97, in __init__
    mod = importlib.import_module(self.SETTINGS_MODULE)
  File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 994, in _gcd_import
  File "<frozen importlib._bootstrap>", line 971, in _find_and_load
  File "<frozen importlib._bootstrap>", line 941, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "<frozen importlib._bootstrap>", line 953, in _find_and_load_unlocked
ModuleNotFoundError: No module named 'freenasUI'
Beginning ZFS volume imports
ZFS volume imports complete
    django.setup()
    self._setup(name)
ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib /usr/local/lib/e2fsprogs /usr/local/lib/nss /usr/local/lib/perl5/5.26/mach/CORE /usr/local/lib/samba4
32-bit compatibility ldconfig path:
Loading kernel modules:
pmc: Unknown Intel CPU.
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI>
Setting hostname: freenas.local.
Setting up harvesting: [UMA],[FS_ATIME],SWI,INTERRUPT,NET_NG,NET_ETHER,NET_TUN,MOUSE,KEYBOARD,ATTACH,CACHED
Feeding entropy: .
re0: link state changed to DOWN
Starting dhclient.
re0: no link .....
re0: link state changed to UP
got link
DHCPDISCOVER on re0 to 255.255.255.255 port 67 interval 4
DHCPDISCOVER on re0 to 255.255.255.255 port 67 interval 9
DHCPOFFER from 192.168.188.1
DHCPREQUEST on re0 to 255.255.255.255 port 67
DHCPACK from 192.168.188.1
bound to 192.168.188.36 -- renewal in 432000 seconds.
Starting Network: lo0 re0.
    options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
    groups: lo
re0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=8209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
    ether 70:85:c2:82:30:a2
    hwaddr 70:85:c2:82:30:a2
    inet 192.168.188.36 netmask 0xffffff00 broadcast 192.168.188.255
    media: Ethernet autoselect (1000baseT <full-duplex,master>)
    status: active
Starting devd.
add host 127.0.0.1: gateway lo0 fib 0: route already in table
add host ::1: gateway lo0 fib 0: route already in table
add net fe80::: gateway ::1
add net ff02::: gateway ::1
add net ::ffff:0.0.0.0: gateway ::1
add net ::0.0.0.0: gateway ::1
  File "/usr/local/libexec/nas/generate_ssl_certificates.py", line 37, in <module>
    main()
  File "/usr/local/libexec/nas/generate_ssl_certificates.py", line 28, in main
    client = Client()
  File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py", line 320, in __init__
    raise e
  File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py", line 313, in __init__
    self._ws.connect()
  File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py", line 170, in connect
    rv = super(WSClient, self).connect()
  File "/usr/local/lib/python3.6/site-packages/ws4py/client/__init__.py", line 208, in connect
    self.sock.connect(self.bind_addr)
FileNotFoundError: [Errno 2] No such file or directory
Creating and/or trimming log files.
Starting syslog_ng.
Starting watchdogd.
Setting up system for textdumps.
debug.ddb.textdump.pending: 0 -> 1
debug.debugger_on_panic: 1 -> 1
debug.ddb.capture.bufsize: 49152 -> 4194304
Starting rpcbind.
Alarm clock
Starting mountd.
NFSv4 is disabled
Starting nfsd.
nfsd: can't register svc name
Starting statd.
Starting lockd.
  File "/usr/local/libexec/nas/generate_sssd_conf.py", line 907, in <module>
    main()
  File "/usr/local/libexec/nas/generate_sssd_conf.py", line 876, in main
    client = Client()
    raise e
    self._ws.connect()
Performing sanity check on openssh configuration.
Starting openssh.
Updating motd:.
Mounting late filesystems:.
Starting ntpd.
Can't load /usr/local/etc/smb4.conf - run testparm to debug it
  File "/usr/local/libexec/nas/generate_smb4_conf.py", line 53, in <module>
    from freenasUI.common.pipesubr import pipeopen
[: ==: unexpected operator
/etc/rc: WARNING: /usr/local/etc/smb4.conf is not readable.
/etc/rc: WARNING: /usr/local/etc/smartd.conf is not readable.
Starting rrdcached.
  File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'settings'
Performing sanity check on nginx configuration:
nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Starting nginx.
  File "/usr/local/libexec/nas/generate_afpd_conf.py", line 206, in <module>
    main()
  File "/usr/local/libexec/nas/generate_afpd_conf.py", line 31, in main
    client = Client()
    raise e
    self._ws.connect()
Starting dbus.
Starting mdnsd.
Starting netatalk.
Starting collectd.
option = Hostname; value = freenas.local;
option = FQDNLookup; value = true;
option = BaseDir; value = /var/db/collectd;
option = PIDFile; value = /var/run/collectd.pid;
Created new plugin context.
plugin_load: plugin "aggregation" successfully loaded.
plugin_load: plugin "cpu" successfully loaded.
plugin_load: plugin "cputemp" successfully loaded.
plugin_load: plugin "ctl" successfully loaded.
plugin_load: plugin "df" successfully loaded.
plugin_load: plugin "disk" successfully loaded.
plugin_load: plugin "exec" successfully loaded.
plugin_load: plugin "geom_stat" successfully loaded.
plugin_load: plugin "interface" successfully loaded.
plugin_load: plugin "load" successfully loaded.
plugin_load: plugin "memory" successfully loaded.
plugin_load: plugin "network" successfully loaded.
plugin_load: plugin "processes" successfully loaded.
plugin_load: plugin "python" successfully loaded.
plugin_load: plugin "rrdcached" successfully loaded.
plugin_load: plugin "swap" successfully loaded.
plugin_load: plugin "uptime" successfully loaded.
May 15 22:06:20 freenas collectd[2966]: Unhandled python exception in init callback: FileNotFoundError: [Errno 2] No such file or directory
May 15 22:06:20 freenas collectd[2966]: Traceback (most recent call last):
May 15 22:06:20 freenas collectd[2966]:   File "/usr/local/lib/collectd_pyplugins/disktemp.py", line 130, in init
    with Client() as c:
May 15 22:06:20 freenas collectd[2966]:   File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py", line 320, in __init__
    raise e
May 15 22:06:20 freenas collectd[2966]:   File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py", line 313, in __init__
    self._ws.connect()
May 15 22:06:20 freenas collectd[2966]:   File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py", line 170, in connect
May 15 22:06:20 freenas collectd[2966]:   File "/usr/local/lib/python3.6/site-packages/ws4py/client/__init__.py", line 208, in connect
May 15 22:06:20 freenas collectd[2966]: FileNotFoundError: [Errno 2] No such file or directory
May 15 22:06:20 freenas collectd[2966]: Unhandled python exception in read callback: AttributeError: 'DiskTemp' object has no attribute 'disks'
May 15 22:06:20 freenas collectd[2966]:   File "/usr/local/lib/collectd_pyplugins/disktemp.py", line 146, in read
    for disk in self.disks:
May 15 22:06:20 freenas collectd[2966]: AttributeError: 'DiskTemp' object has no attribute 'disks'
Syncing multipaths...
Flushed all rules.
Starting zfsd.
Configuring vt: blanktime.
Starting cron.
Wed May 15 22:06:23 CEST 2019
pid 2042 (syslog-ng), uid 0: exited on signal 6 (core dumped)
May 15 22:07:08 freenas init: getty repeating too quickly on port /dev/ttyv0, sleeping 30 secs
I think the problem starts here:
Does anyone have any idea what happened here? I would be so grateful, I don't want to have to set up the whole system anew...
I am using FreeNAS-11.2-U3
My Hardware:
- Asrock J4205-ITX with Intel Pentium J4205 / 2.6 GHz (Quad-Core)
- WD Green SSD 120 GB
- Some WD Reds for Storage
- Crucial CT2KIT51264BF160BJ 8GB (4GBx2)
gr4ni
I was now so far that I would have simply reinstalled the system, because I had no more idea what I should do.
During the installation process I saw that there was also the possibility for an update. See screenshot:
NOTE: In the next window I have selected "Format the boot device".
After that everything worked again and all my settings including jails are still there :) This can be marked as solved.
