WebUI fails to load and maybe slow SMB copy
thisman105
When copying files from the Seagate array to the same array, I am getting about 33 MB/s using Windows 10 drag and drop on large files. Is this a normal speed for my setup? I thought it should be more. Is there a better way to drag and drop copy files from one place on the array to another? Also, I have noticed that the web UI doesn't load all the way most of the time and I have to refresh it a few times to get in. What's up with that?
SuperMicro MBD-X10SL7-F-O
Intel Xeon E3-1231V3
CoolerMaster Hyper 212 Evo
Rosewill Capstone 450w Gold
3x Seagate 4TB Nas drives RAIDZ
2x IBM 15k SAS drives Striped
2x 8GB Kingston ECC
2x 8GB Crucial ECC
Chenbro SR20969-CO
8x hot swap bays
ESXI 6.5
PCI-E passthrough LSI2308 IT mode to
FreeNAS-9.10 (16GB dedicated ram)
Plugins:
-Transmission
-Plex (unused atm)
Thanks,
Rob
thisman105
bump
D
dlavigne
Guest
That's a pretty old version of FreeNAS...
Were you able to resolve this? If not, do you have a plan to upgrade to a newer version (starting with 11.0) to see if that resolves it?
thisman105
I was not able to resolve so I updated yesterday to FreeNAS-11.2-RELEASE (Build Date: Dec 5, 2018 21:28) and now I cannot get OpenVPN working in my Transmission jail. I see bug 40872 for RC2 but they say it "should" just work in the stable release and the fix mentioned there does not seem to work for me. "WARNING: failed to start openvpn" and no tun exists. Any ideas on that?
Thanks
