WebGUI does not show IP address. Network Columns not sticky
quist
I am using FreeNAS on the following system:
Version: FreeNAS-11.2-RELEASE-U1
Physical Memory: 8142 MiB
Model: Intel(R) Xeon(R) CPU X3360 @ 2.83GHz
Using the WebGUI in the Network -> Interface section:
The IP address is not shown
When I adjust the COLUMNS, the ones chosen do not persist. The default Select All seems to remain
Chris Moore
details? You are not giving enough...
I would have to guess that you are using DHCP to get the IP address and that is not displayed because it is dynamic.
Adjustments to the columns in the UI have never been persistent. You could submit a bug report.
