Hi, first post!
I had a spare disk in my fairly new TrueNas (latest release) server. I wanted to remove it from the system, relocate it on a different controller, than add it to an existing raid pool. I attempted to remove it from the ui, which it indicated it was working on it. Then shortly after my interface went away with a message:
Connecting to TrueNAS ... Make sure the TrueNAS system is powered on and connected to the network.
I am still SSH into the machine and I can connect and transfer/browse stuff around through SMB shares just fine. I tried another browser for kicks and got the same message.
I would like to gracefully shutdown the machine, but when I try to sudo shutdown, it is telling me the root password is not correct. I used the password used in creating the machine (the same I log into the UI with), as well as "freenas" and "abcd1234". I have no idea what the password might be otherwise. Short of just powering it off, I feel out of options - any suggestions?
Thank you.
Thank you.
