WD has a utility to update RED drives that are experiencing high load cycle counts (LCC). It's called wd5741 and can be found at:
http://support.wdc.com/product/download.asp?groupid=619&sid=201&lang=en
I noticed one of my WD 3TB drives had an LCC of over 23k in less than a month of operation and the counts were increasing by over 100 each hour. Searching I found some users had addressed this using wdidle3 to adjust idle time although it was not specifically approved by WD for use with RED drives.
I used the wd5741 utility on my five 3TB RED drives, three of which took the update. The other two that I had just purchased reported that the update was not needed. So it appears WD has adopted this change as standard. After the update no more issues with LCC.
Hope this helps someone.
