Sorry, but that's very wrong. I'll explain...
All of the hard drive manufacturers have the same maximum density per square inch, which translates into so much data per platter. There's a relationship between data density, number of platters, performance, reliability, power usage, and more. In some cases, you want fewer platters, on others you might want more. But, all of the manufacturers have roughly the same density per platter. No joke, some people are so hard-core into this stuff they actually shop for drives with fewer platters or more platters based on the intended use. It can and does matter to many people. So while you might want "a 4TB drive for your server" someone else may be shopping for "a 4TB drive that is more than 3 platters". I've known people that would buy 8 4-platter drives, then when the same size disk is available in 3 platters they'd "upgrade".
I think that the most platters you can put in a standard 3.5" is 4 or 5. And the biggest disks naturally have more platters and the higher/highest density. Virtually all hard drive manufacturers are at about 1TB/platter. Nobody really as a significant advantage over the others, otherwise they'd be able to make a bigger drive. Currently if you look around you'll see everyone is at 4TB.. because that's the maximum density everyone has achieved.
There is one exception, and that is the Helium filled drive made by HGST that is 6TB. I won't even discuss how the helium increases density, but it's actually much more complex than people realize. It's sealed, and at just $800+ a disk, I'm sure you're going to buy 24 of them for your server. ;) It's an odd ball and there's a lot of talk about how sustainable a He drive industry could go since Helium is getting more expensive by the day. There's also a rapidly diminishing quantity of He on the planet since it's lighter than air and is carried away by the solar winds. One of the dollar stores here in town doesn't even carry He for their balloons anymore because its too expensive.
ouchhhhh!!
Anyway, you probably made up those numbers just to explain yourself, but if WD was able to make a 3TB/platter density while Seagate could only make 1TB/platter, Seagate would be in SERIOUSLY bad shape financially because WD could drop a 10TB+ drive on the market right now while Seagate would be limited to 4TB or so. Naturally, Seagate wouldn't be in business long. ;)
