VOLUME STATUS
mst
I have a couple disk listed as unavailable so I removed (detached) them but they still show up in the volume status.
The version you're on (seems maybe FreeNAS 9.10?) is not able to remove disks from a RAIDZ VDEV, so I don't see how you could have done that. (actually no version can do that yet)
Did you mean that you physically took the disks out of the system (which would match with what you see there)?
Until you replace them with new disks and the resilver completes, you're likely to continue to see those member disks showing as unavailable.
