Volume disappeared after running the "reset to factory defaults" in CLI
daf
Dear all, I have a freenas system with 2 zpools, 1 consists of 8 drives zraid2 labeled "Tank" and a 3 drive zraid1 labeled "Test"
After running into some networking trouble I decided to invoke the "reset to factory defaults"
After rebooting I was able to import "Tank" from the GUI, but no signs of the volume "Test"
I read quite some posts on the forum but I cannot find a way to relocate Test en import it again..
All HDD drives are available...
zpool history just gives me info about the current pools
Here's some info:
I hope I can invoke a forced imput by pointing to one of the drives that is part of "Test" but not really sure how..
I simply cannot find anything related to "Test" anymore..
zpool status
pool: Tank
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
Tank ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/c19f8fb6-4839-11e7-b13a-0025905df118 ONLINE 0 0 0
gptid/c238d324-4839-11e7-b13a-0025905df118 ONLINE 0 0 0
gptid/c2d885f3-4839-11e7-b13a-0025905df118 ONLINE 0 0 0
gptid/c37842bb-4839-11e7-b13a-0025905df118 ONLINE 0 0 0
gptid/c438214b-4839-11e7-b13a-0025905df118 ONLINE 0 0 0
gptid/c4dec13c-4839-11e7-b13a-0025905df118 ONLINE 0 0 0
gptid/c5c758c9-4839-11e7-b13a-0025905df118 ONLINE 0 0 0
gptid/c679142e-4839-11e7-b13a-0025905df118 ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h0m with 0 errors on Sun Jun 4 18:45:31 2017
freenas-boot ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
camcontrol devlist
<ATA WDC WD4000FYYZ-0 1K01> at scbus0 target 19 lun 0 (pass0,da0)
<ATA HGST HUH721010AL W21D> at scbus0 target 20 lun 0 (pass1,da1)
<ATA ST10000NM0016-1T SNB0> at scbus0 target 21 lun 0 (pass2,da2)
<ATA WDC WD4000FYYZ-0 1K01> at scbus0 target 25 lun 0 (pass3,da3)
<ATA HGST HUH721010AL W21D> at scbus0 target 26 lun 0 (pass4,da4)
<ATA HGST HUH721010AL T21D> at scbus0 target 27 lun 0 (pass5,da5)
<ATA WDC WD4000FYYZ-0 1K04> at scbus0 target 31 lun 0 (pass6,da6)
<ATA HGST HUH721010AL W21D> at scbus0 target 32 lun 0 (pass7,da7)
<ATA HGST HUH721010AL T21D> at scbus0 target 33 lun 0 (pass8,da8)
<ATA HGST HUH721010AL W21D> at scbus0 target 38 lun 0 (pass9,da9)
<ATA HGST HUH721010AL T21D> at scbus0 target 39 lun 0 (pass10,da10)
<LSI CORP SAS2X36 0717> at scbus0 target 40 lun 0 (pass11,ses0)
<KINGSTON SV300S37A60G 505ABBF1> at scbus1 target 0 lun 0 (pass12,ada0)
<C300-CTFDDAC064MAG 0006> at scbus2 target 0 lun 0 (pass13,ada1)
gpart show
=> 34 117231341 ada0 GPT (56G)
34 204800 1 efi (100M)
204834 6 - free - (3.0K)
204840 117026528 2 freebsd-zfs (56G)
117231368 7 - free - (3.5K)
=> 63 125045361 ada1 MBR (60G)
63 1985 - free - (993K)
2048 119881728 1 linux-data [active] (57G)
119883776 2046 - free - (1.0M)
119885822 5158914 2 ebr (2.5G)
125044736 688 - free - (344K)
=> 40 7814037088 da0 GPT (3.6T)
40 88 - free - (44K)
128 4194304 1 freebsd-swap (2.0G)
4194432 7809842688 2 freebsd-zfs (3.6T)
7814037120 8 - free - (4.0K)
=> 40 19532873648 da1 GPT (9.1T)
4194432 19528679248 2 freebsd-zfs (9.1T)
19532873680 8 - free - (4.0K)
=> 40 19532873648 da2 GPT (9.1T)
=> 40 7814037088 da3 GPT (3.6T)
=> 40 19532873648 da4 GPT (9.1T)
=> 40 19532873648 da5 GPT (9.1T)
=> 40 7814037088 da6 GPT (3.6T)
=> 40 19532873648 da7 GPT (9.1T)
=> 40 19532873648 da8 GPT (9.1T)
=> 40 19532873648 da9 GPT (9.1T)
=> 40 19532873648 da10 GPT (9.1T)
=> 0 5158914 ada1s2 EBR (2.5G)
0 5158914 1 linux-swap (2.5G)
Any hints on how to go from here?
Thanks in advance,
Daf
daf
Thanks for your answer, but importing the pool is what I'm trying to establish here...
In Storage → Volumes → Import Volume, the only volume showing up in the drop down box was "Tank" (no sign of "Test")
Running
zpool import
from the shell doens't do anything.. The disks however are available when you look at the output from camcontrol devlist
SweetAndLow
Sweet'NASty
Running
zpool import
gpart show output? Looks like there is no pool created on those other disks.
daf
I'm really sure there used to be a pool on these 4TB drives.. It also contained quite some data..
I'm thinking it could be that this particular pool was created wth zfs on linux and not with freenas at the time I was running a dual boot with a linux system.. Could that be the reason?
Let's try to install linux once more and see if I can import the pool from there..
daf
No sign of the pool in ZOL as well... Could it be "reset to factory defaults" accidently destroyed one of the pools?
zpool import -D however doesn't show signs of a destroyed pool as well..
SweetAndLow
Sweet'NASty
You would have to create a test scenario to try it out. I highly doubt it got deleted by freenas. Much more likely it got deleted by a human. zpool history might give some insight into what commands have been executed.
daf
Hi there, once again thanks for your reply. I'm absolutely sure there was a volume called "Test" containing my data at the moment I invoked the "Reset to factory default" command and that the volume mysteriously disappeared.
zpool histroy just gives me info about the 2 volumes (root and Tank) that are actually available..
My current priority is getting my data back.. after that I will try some test to see if I can reproduce this..
Anyone that has some advice what I can try to get my data back??
Kind regards,
Daf
gpsguy
Active Member
Please provide detailed hardware information, as well as FreeNAS version.
Do you have a hardware RAID controller in your server?
daf
joeschmuck
Old Man
My initial thought is the pool was accidentally destroyed by the operator by accident but you are insisting that it was actively there before performing a Factory Reset. I certainly hope this isn't the case but we have to take you at your word.
Let me ask you a few questions...
You were already asked for the output of zpool history so please provide it. This will speak volumes.
If you want to try something then my unorthodox methods would be as follows (after you provide the data previously requested):
1) Shut down the machine.
2) Unplug your drive chassis.
3) Move the three drives for pool Test to the SATA ports marked SATA 1, 2, 3. I want to use the SoC controller directly.
4) Boot up your machine and try to import your pool. You will likely have errors about the pool "Tank" not being present, that is okay.
5) If your pool "Test" imports then report it here and count your blessings.
I don't want to go any further, lets see how this goes.
daf
Hi Joeschmuck, thanks for your reply!
Here's the output of "zpool history":
root@freenas:~ # zpool history
History for 'Tank':
2017-06-03.01:51:04 zpool create -o cachefile=/data/zfs/zpool.cache -o failmode=continue -o autoexpand=on -O compression=lz4 -O aclmode=passthrough -O aclinherit=passthrough -f -m /Tank -o altroot=/mnt Tank raidz2 /dev/gptid/c19f8fb6-4839-11e7-b13a-0025905df118 /dev/gptid/c238d324-4839-11e7-b13a-0025905df118 /dev/gptid/c2d885f3-4839-11e7-b13a-0025905df118 /dev/gptid/c37842bb-4839-11e7-b13a-0025905df118 /dev/gptid/c438214b-4839-11e7-b13a-0025905df118 /dev/gptid/c4dec13c-4839-11e7-b13a-0025905df118 /dev/gptid/c5c758c9-4839-11e7-b13a-0025905df118 /dev/gptid/c679142e-4839-11e7-b13a-0025905df118
2017-06-03.01:51:09 zfs inherit mountpoint Tank
2017-06-03.01:51:09 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-03.14:05:35 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-03.14:05:35 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-04.00:14:28 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-04.00:14:28 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-07.09:02:50 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-07.09:02:50 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-22.09:36:12 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-22.09:36:12 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-22.09:40:39 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-22.09:40:39 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-22.10:53:22 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-22.10:53:22 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-22.11:14:26 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-22.11:14:26 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-22.11:25:16 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-22.11:25:16 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-22.11:34:33 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-22.11:34:33 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-22.14:39:48 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-22.14:39:48 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-23.08:48:14 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-23.08:48:14 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-24.14:06:08 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-24.14:06:08 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-26.06:20:51 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-26.06:20:51 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-26.14:18:05 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-26.14:18:05 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-26.15:23:36 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-26.15:23:36 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-27.12:54:08 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-27.12:54:08 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-28.00:46:23 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-28.00:46:23 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-28.07:23:45 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-28.07:23:45 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-28.11:03:57 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-28.11:03:57 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-28.12:21:56 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-28.12:21:56 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-28.12:26:36 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-28.12:26:36 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-28.12:36:13 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-28.12:36:13 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-28.12:43:36 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-28.12:43:36 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-29.13:01:07 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-29.13:01:07 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-29.13:35:49 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-29.13:35:49 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-29.13:42:17 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-29.13:42:17 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-29.13:51:25 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-29.13:51:25 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-29.14:00:57 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-29.14:00:57 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-29.14:12:11 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-29.14:12:11 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-29.14:24:28 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-29.14:24:28 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-29.14:32:24 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-29.14:32:24 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-29.14:48:36 zpool import -f -R /mnt 13188710535575479647
2017-06-29.14:48:36 zfs inherit -r mountpoint Tank
2017-06-29.14:48:36 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-29.14:48:37 zfs set aclmode=passthrough Tank
2017-06-29.14:48:42 zfs set aclinherit=passthrough Tank
2017-06-29.14:48:43 zfs create -o mountpoint=legacy Tank/.system
2017-06-29.14:48:44 zfs create -o mountpoint=legacy Tank/.system/cores
2017-06-29.14:48:44 zfs create -o mountpoint=legacy Tank/.system/samba4
2017-06-29.14:48:44 zfs create -o mountpoint=legacy Tank/.system/syslog-7d98fa5005d94efa8af880350241ec56
2017-06-29.14:48:45 zfs create -o mountpoint=legacy Tank/.system/rrd-7d98fa5005d94efa8af880350241ec56
2017-06-29.14:48:49 zfs create -o mountpoint=legacy Tank/.system/configs-7d98fa5005d94efa8af880350241ec56
2017-06-29.14:53:35 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-29.14:53:35 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-29.15:25:13 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-29.15:25:13 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-30.14:57:01 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-30.14:57:01 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-06-30.15:08:20 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-06-30.15:08:20 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-07-02.02:37:09 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-07-02.02:37:09 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-07-02.02:57:58 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-07-02.02:57:58 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-07-02.07:57:46 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-07-02.07:57:46 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-07-02.12:30:24 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-07-02.12:30:24 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-07-02.12:39:51 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-07-02.12:39:51 zpool set cachefile=/data/zfs/zpool.cache Tank
2017-07-02.12:49:42 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 13188710535575479647
2017-07-02.12:49:42 zpool set cachefile=/data/zfs/zpool.cache Tank
History for 'freenas-boot':
2017-04-15.06:38:23 zpool create -f -o cachefile=/tmp/zpool.cache -o version=28 -O mountpoint=none -O atime=off -O canmount=off freenas-boot ada0p2
2017-04-15.06:38:23 zpool set feature@async_destroy=enabled freenas-boot
2017-04-15.06:38:23 zpool set feature@empty_bpobj=enabled freenas-boot
2017-04-15.06:38:23 zpool set feature@lz4_compress=enabled freenas-boot
2017-04-15.06:38:23 zfs set compress=lz4 freenas-boot
2017-04-15.06:38:23 zfs create -o canmount=off freenas-boot/ROOT
2017-04-15.06:38:23 zfs create -o mountpoint=legacy freenas-boot/ROOT/default
2017-04-15.06:38:28 zfs create -o mountpoint=legacy freenas-boot/grub
2017-04-15.06:39:47 zpool set bootfs=freenas-boot/ROOT/default freenas-boot
2017-04-15.06:39:47 zpool set cachefile=/boot/zfs/rpool.cache freenas-boot
2017-04-15.06:39:53 zfs set beadm:nickname=default freenas-boot/ROOT/default
2017-04-15.06:47:44 zfs snapshot -r freenas-boot/ROOT/default@2017-04-15-06:47:44
2017-04-15.06:47:45 zfs clone -o canmount=off -o mountpoint=legacy freenas-boot/ROOT/default@2017-04-15-06:47:44 freenas-boot/ROOT/Initial-Install
2017-04-15.06:47:50 zfs set beadm:nickname=Initial-Install freenas-boot/ROOT/Initial-Install
2017-04-15.07:07:01 zfs snapshot -r freenas-boot/ROOT/default@2017-04-15-07:07:01
2017-04-15.07:07:01 zfs clone -o canmount=off -o mountpoint=legacy freenas-boot/ROOT/default@2017-04-15-07:07:01 freenas-boot/ROOT/9.10-MASTER-201704150516
2017-04-15.07:07:03 zfs set beadm:nickname=9.10-MASTER-201704150516 freenas-boot/ROOT/9.10-MASTER-201704150516
2017-04-15.07:08:38 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704150516
2017-04-15.07:08:38 zfs set mountpoint=/tmp/BE-9.10-MASTER-201704150516.cSnGO6eB freenas-boot/ROOT/9.10-MASTER-201704150516
2017-04-15.07:08:38 zfs set mountpoint=/ freenas-boot/ROOT/9.10-MASTER-201704150516
2017-04-15.07:08:38 zpool set bootfs=freenas-boot/ROOT/9.10-MASTER-201704150516 freenas-boot
2017-04-15.07:08:38 zfs set canmount=noauto freenas-boot/ROOT/Initial-Install
2017-04-15.07:08:38 zfs set canmount=noauto freenas-boot/ROOT/default
2017-04-15.07:08:40 zfs promote freenas-boot/ROOT/9.10-MASTER-201704150516
2017-04-18.13:06:36 zfs snapshot -r freenas-boot/ROOT/9.10-MASTER-201704150516@2017-04-18-13:06:36
2017-04-18.13:06:37 zfs clone -o canmount=off -o beadm:keep=False -o mountpoint=/ freenas-boot/ROOT/9.10-MASTER-201704150516@2017-04-18-13:06:36 freenas-boot/ROOT/9.10-MASTER-201704180409
2017-04-18.13:06:40 zfs set beadm:nickname=9.10-MASTER-201704180409 freenas-boot/ROOT/9.10-MASTER-201704180409
2017-04-18.13:06:42  zfs set sync=disabled freenas-boot/ROOT/9.10-MASTER-201704180409
2017-04-18.13:09:35  zfs inherit  freenas-boot/ROOT/9.10-MASTER-201704180409
2017-04-18.13:09:35 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704180409
2017-04-18.13:09:35 zfs set mountpoint=/tmp/BE-9.10-MASTER-201704180409.Z0Ttq8DN freenas-boot/ROOT/9.10-MASTER-201704180409
2017-04-18.13:09:35 zfs set mountpoint=/ freenas-boot/ROOT/9.10-MASTER-201704180409
2017-04-18.13:09:35 zpool set bootfs=freenas-boot/ROOT/9.10-MASTER-201704180409 freenas-boot
2017-04-18.13:09:35 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704150516
2017-04-18.13:09:35 zfs set canmount=noauto freenas-boot/ROOT/Initial-Install
2017-04-18.13:09:35 zfs set canmount=noauto freenas-boot/ROOT/default
2017-04-18.13:09:38 zfs promote freenas-boot/ROOT/9.10-MASTER-201704180409
2017-04-23.05:56:16 zfs snapshot -r freenas-boot/ROOT/9.10-MASTER-201704180409@2017-04-23-05:56:16
2017-04-23.05:56:17 zfs clone -o canmount=off -o beadm:keep=False -o mountpoint=/ freenas-boot/ROOT/9.10-MASTER-201704180409@2017-04-23-05:56:16 freenas-boot/ROOT/11-MASTER-201704230409
2017-04-23.05:56:20 zfs set beadm:nickname=11-MASTER-201704230409 freenas-boot/ROOT/11-MASTER-201704230409
2017-04-23.05:56:23  zfs set sync=disabled freenas-boot/ROOT/11-MASTER-201704230409
2017-04-23.05:59:09  zfs inherit  freenas-boot/ROOT/11-MASTER-201704230409
2017-04-23.05:59:09 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201704230409
2017-04-23.05:59:09 zfs set mountpoint=/tmp/BE-11-MASTER-201704230409.90OhXsmw freenas-boot/ROOT/11-MASTER-201704230409
2017-04-23.05:59:09 zfs set mountpoint=/ freenas-boot/ROOT/11-MASTER-201704230409
2017-04-23.05:59:09 zpool set bootfs=freenas-boot/ROOT/11-MASTER-201704230409 freenas-boot
2017-04-23.05:59:09 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704150516
2017-04-23.05:59:09 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704180409
2017-04-23.05:59:09 zfs set canmount=noauto freenas-boot/ROOT/Initial-Install
2017-04-23.05:59:09 zfs set canmount=noauto freenas-boot/ROOT/default
2017-04-23.05:59:12 zfs promote freenas-boot/ROOT/11-MASTER-201704230409
2017-04-27.08:00:51 zfs snapshot -r freenas-boot/ROOT/11-MASTER-201704230409@2017-04-27-08:00:51
2017-04-27.08:00:52 zfs clone -o canmount=off -o beadm:keep=False -o mountpoint=/ freenas-boot/ROOT/11-MASTER-201704230409@2017-04-27-08:00:51 freenas-boot/ROOT/11-MASTER-201704270409
2017-04-27.08:00:55 zfs set beadm:nickname=11-MASTER-201704270409 freenas-boot/ROOT/11-MASTER-201704270409
2017-04-27.08:00:58  zfs set sync=disabled freenas-boot/ROOT/11-MASTER-201704270409
2017-04-27.08:03:43  zfs inherit  freenas-boot/ROOT/11-MASTER-201704270409
2017-04-27.08:03:43 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201704270409
2017-04-27.08:03:43 zfs set mountpoint=/tmp/BE-11-MASTER-201704270409.IvaOqqJy freenas-boot/ROOT/11-MASTER-201704270409
2017-04-27.08:03:43 zfs set mountpoint=/ freenas-boot/ROOT/11-MASTER-201704270409
2017-04-27.08:03:43 zpool set bootfs=freenas-boot/ROOT/11-MASTER-201704270409 freenas-boot
2017-04-27.08:03:43 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201704230409
2017-04-27.08:03:43 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704150516
2017-04-27.08:03:43 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704180409
2017-04-27.08:03:43 zfs set canmount=noauto freenas-boot/ROOT/Initial-Install
2017-04-27.08:03:43 zfs set canmount=noauto freenas-boot/ROOT/default
2017-04-27.08:03:46 zfs promote freenas-boot/ROOT/11-MASTER-201704270409
2017-05-10.01:45:30 zfs snapshot -r freenas-boot/ROOT/11-MASTER-201704270409@2017-05-10-10:45:30
2017-05-10.01:45:31 zfs clone -o canmount=off -o beadm:keep=False -o mountpoint=/ freenas-boot/ROOT/11-MASTER-201704270409@2017-05-10-10:45:30 freenas-boot/ROOT/11.0-RC
2017-05-10.01:45:34 zfs set beadm:nickname=11.0-RC freenas-boot/ROOT/11.0-RC
2017-05-10.01:45:38  zfs set sync=disabled freenas-boot/ROOT/11.0-RC
2017-05-10.01:48:03  zfs inherit  freenas-boot/ROOT/11.0-RC
2017-05-10.01:48:03 zfs set canmount=noauto freenas-boot/ROOT/11.0-RC
2017-05-10.01:48:03 zfs set mountpoint=/tmp/BE-11.0-RC.U05hTAuc freenas-boot/ROOT/11.0-RC
2017-05-10.01:48:04 zfs set mountpoint=/ freenas-boot/ROOT/11.0-RC
2017-05-10.01:48:04 zpool set bootfs=freenas-boot/ROOT/11.0-RC freenas-boot
2017-05-10.01:48:04 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201704230409
2017-05-10.01:48:04 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201704270409
2017-05-10.01:48:04 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704150516
2017-05-10.01:48:04 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704180409
2017-05-10.01:48:04 zfs set canmount=noauto freenas-boot/ROOT/Initial-Install
2017-05-10.01:48:04 zfs set canmount=noauto freenas-boot/ROOT/default
2017-05-10.01:48:07 zfs promote freenas-boot/ROOT/11.0-RC
2017-05-10.02:00:05 zfs snapshot -r freenas-boot/ROOT/11.0-RC@2017-05-10-11:00:05
2017-05-10.02:00:06 zfs clone -o canmount=off -o beadm:keep=False -o mountpoint=/ freenas-boot/ROOT/11.0-RC@2017-05-10-11:00:05 freenas-boot/ROOT/11-MASTER-201705100408
2017-05-10.02:00:09 zfs set beadm:nickname=11-MASTER-201705100408 freenas-boot/ROOT/11-MASTER-201705100408
2017-05-10.02:00:13  zfs set sync=disabled freenas-boot/ROOT/11-MASTER-201705100408
2017-05-10.02:02:39  zfs inherit  freenas-boot/ROOT/11-MASTER-201705100408
2017-05-10.02:02:39 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201705100408
2017-05-10.02:02:39 zfs set mountpoint=/tmp/BE-11-MASTER-201705100408.kfnVZ8z1 freenas-boot/ROOT/11-MASTER-201705100408
2017-05-10.02:02:39 zfs set mountpoint=/ freenas-boot/ROOT/11-MASTER-201705100408
2017-05-10.02:02:39 zpool set bootfs=freenas-boot/ROOT/11-MASTER-201705100408 freenas-boot
2017-05-10.02:02:39 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201704230409
2017-05-10.02:02:39 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201704270409
2017-05-10.02:02:39 zfs set canmount=noauto freenas-boot/ROOT/11.0-RC
2017-05-10.02:02:39 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704150516
2017-05-10.02:02:39 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704180409
2017-05-10.02:02:39 zfs set canmount=noauto freenas-boot/ROOT/Initial-Install
2017-05-10.02:02:39 zfs set canmount=noauto freenas-boot/ROOT/default
2017-05-10.02:02:42 zfs promote freenas-boot/ROOT/11-MASTER-201705100408
2017-05-26.07:59:04 zfs snapshot -r freenas-boot/ROOT/11-MASTER-201705100408@2017-05-26-16:59:04
2017-05-26.07:59:05 zfs clone -o canmount=off -o beadm:keep=False -o mountpoint=/ freenas-boot/ROOT/11-MASTER-201705100408@2017-05-26-16:59:04 freenas-boot/ROOT/11.0-RC3
2017-05-26.07:59:08 zfs set beadm:nickname=11.0-RC3 freenas-boot/ROOT/11.0-RC3
2017-05-26.07:59:13  zfs set sync=disabled freenas-boot/ROOT/11.0-RC3
2017-05-26.08:01:38  zfs inherit  freenas-boot/ROOT/11.0-RC3
2017-05-26.08:01:39 zfs set canmount=noauto freenas-boot/ROOT/11.0-RC3
2017-05-26.08:01:39 zfs set mountpoint=/tmp/BE-11.0-RC3.s4ryo7r1 freenas-boot/ROOT/11.0-RC3
2017-05-26.08:01:39 zfs set mountpoint=/ freenas-boot/ROOT/11.0-RC3
2017-05-26.08:01:39 zpool set bootfs=freenas-boot/ROOT/11.0-RC3 freenas-boot
2017-05-26.08:01:39 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201704230409
2017-05-26.08:01:39 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201704270409
2017-05-26.08:01:39 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201705100408
2017-05-26.08:01:39 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704150516
2017-05-26.08:01:39 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704180409
2017-05-26.08:01:39 zfs set canmount=noauto freenas-boot/ROOT/Initial-Install
2017-05-26.08:01:39 zfs set canmount=noauto freenas-boot/ROOT/default
2017-05-26.08:01:42 zfs promote freenas-boot/ROOT/11.0-RC3
2017-06-04.18:45:06 zpool scrub freenas-boot
2017-06-22.09:29:01 zfs snapshot -r freenas-boot/ROOT/11.0-RC3@2017-06-22-18:29:01
2017-06-22.09:29:02 zfs clone -o canmount=off -o beadm:keep=False -o mountpoint=/ freenas-boot/ROOT/11.0-RC3@2017-06-22-18:29:01 freenas-boot/ROOT/11.0-RELEASE
2017-06-22.09:29:07 zfs set beadm:nickname=11.0-RELEASE freenas-boot/ROOT/11.0-RELEASE
2017-06-22.09:29:14  zfs set sync=disabled freenas-boot/ROOT/11.0-RELEASE
2017-06-22.09:31:45  zfs inherit  freenas-boot/ROOT/11.0-RELEASE
2017-06-22.09:31:45 zfs set canmount=noauto freenas-boot/ROOT/11.0-RELEASE
2017-06-22.09:31:45 zfs set mountpoint=/tmp/BE-11.0-RELEASE.9H3VQLoR freenas-boot/ROOT/11.0-RELEASE
2017-06-22.09:31:45 zfs set mountpoint=/ freenas-boot/ROOT/11.0-RELEASE
2017-06-22.09:31:45 zpool set bootfs=freenas-boot/ROOT/11.0-RELEASE freenas-boot
2017-06-22.09:31:45 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201704230409
2017-06-22.09:31:45 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201704270409
2017-06-22.09:31:45 zfs set canmount=noauto freenas-boot/ROOT/11-MASTER-201705100408
2017-06-22.09:31:45 zfs set canmount=noauto freenas-boot/ROOT/11.0-RC
2017-06-22.09:31:45 zfs set canmount=noauto freenas-boot/ROOT/11.0-RC3
2017-06-22.09:31:45 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704150516
2017-06-22.09:31:45 zfs set canmount=noauto freenas-boot/ROOT/9.10-MASTER-201704180409
2017-06-22.09:31:46 zfs set canmount=noauto freenas-boot/ROOT/Initial-Install
2017-06-22.09:31:46 zfs set canmount=noauto freenas-boot/ROOT/default
2017-06-22.09:31:50 zfs promote freenas-boot/ROOT/11.0-RELEASE
I will try your suggestion later this week although I'm a bit hesitant since I don't want to lose the data on "Tank"; I'm currently in the process of setting up a backup server for this particular volume, so maybe I'll wait with trying your suggestion untill I have Tank backed up..
In the zpool history output I don't see anything fiddly..
