VMware Physical Disk Encryption Problem
xLab
Hi.
I have these options enabled when installing freenas, but this option disappears after I add a SCSI disk.
How can I provide security in this regard?
I need a only VMware virtual disk security.
scrappy
Can you post your FreeNAS system configuration as per forum rules?
If you want ZFS storage pool encryption you must enable it from FreeNAS - not VMware.
xLab
ZFS storage pool encryption is ok encrypted.
i need a vmware virtual disk encryption.
This option is gone when we add a scsi physical disk
scrappy
Because when you perform a physical disk pass-through that drive is handed directly to FreeNAS at the hardware level. Basically, VMware isn't even in the picture.
