VM management on web ui
Samuel Tai
Yes, this reflects the web state. By the way, where do you have your system dataset?
Chavell3
with system dataset you mean boot/system installation?
I've installed the system on 2x USB 3.0 Stick in mirrored mode.
Samuel Tai
No, System->System Dataset. If this is still on the boot stick, the database will be too slow to keep up. This should be set on the main storage pool.
Chavell3
ah okay, I was wrong the system dataset is on my general data pool that consists of 3x HDD and 2x SDD as a cache.
c77dk
I'm experiencing the same behavior (Ubuntu 18.04 UEFI guest), but haven't been digging deeper yet. Had a 1TB replication via IPsec and ssh to wait for, before messing too much with the system :smile:
Chavell3
is the VM feature really usable or is it more a paper feature? It's on the papers but not really usable?
Patrick M. Hausen
I use it @work in production having replaced 3 ESXi servers and @home in semi-production, i.e. serious applications, but occasional downtime because I try new things is ok. Various Ubuntu and Windows VMs.
Takeaways for me:
Don't expect the VNC console to be usable beyond installation and troubleshooting.
Use serial consoles for everything Unixy, i.e. Linux.
Use RDP for Windows.
VirtIO everything.
Samuel Tai
bhyve is a type 2 hypervisor, and it's still pretty immature compared to type 1 hypervisors like ESX, Hyper-V, or Xen. Even compared to other type 2 hypervisors like VirtualBox, it's about 3 years behind in terms of feature set and stability. It's usable and stable enough in production, but only if you understand its limitations.
