I was just testing a VM in TrueNAS 12.0 but after I rebooted the VM it didn't come back up. The Web UI thinks the VM is up, but if I try to power off I get:
If I press "stop" I get:
Running the same command in myself (
internal error: Child process (/usr/sbin/bhyvectl --destroy --vm=3_debian) unexpected exit status 1
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 137, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1202, in _call
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1106, in run_in_executor
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 977, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 1575, in poweroff
self.vms[vm_data['name']].poweroff()
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 273, in poweroff
self.domain.destroy()
File "/usr/local/lib/python3.8/site-packages/libvirt.py", line 1309, in destroy
if ret == -1: raise libvirtError ('virDomainDestroy() failed', dom=self)
libvirt.libvirtError: internal error: Child process (/usr/sbin/bhyvectl --destroy --vm=3_debian) unexpected exit status 1If I press "stop" I get:
File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run
await self.future
File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 399, in __run_body
rv = await self.middleware.run_in_thread(self.method, *([self] + args))
File "/usr/local/lib/python3.8/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 1563, in stop
vm.stop(vm_data['shutdown_timeout'])
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 251, in stop
self.domain.shutdown()
File "/usr/local/lib/python3.8/site-packages/libvirt.py", line 2659, in shutdown
if ret == -1: raise libvirtError ('virDomainShutdown() failed', dom=self)
libvirt.libvirtError: An error occurred, but the cause is unknownRunning the same command in myself (
/usr/sbin/bhyvectl --destroy --vm=3_debian) the error I get is: Code:
VM:3_debian is not created.
