VM management on web ui
Chavell3
HI everybody,
I have a fresh installation of TrueNAS and wanted to use the virtual machine feature.
The first try to install this VM was okay, but later on the VNC connection dropped and the VM was in a stale state.
I tried to stop the VM from the web ui, but unfortunatly got only an error and so the VM is not manageable... as it can't be stopped...
maybe does someone have some experience around the VM feature usage and this error?
See attached the error from the web ui, I get when I try to stop the VM.
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run
    await self.future
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 399, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *([self] + args))
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
    return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 977, in nf
    return f(*args, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 1563, in stop
    vm.stop(vm_data['shutdown_timeout'])
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 251, in stop
    self.domain.shutdown()
  File "/usr/local/lib/python3.8/site-packages/libvirt.py", line 2659, in shutdown
    if ret == -1: raise libvirtError ('virDomainShutdown() failed', dom=self)
libvirt.libvirtError: An error occurred, but the cause is unknown
Thanks.
BR
Chavell3
Chavell3
btw...
can someone tell me, what VM disk formats are supported for VM used with TrueNAS?
Chavell3
Patrick M. Hausen
Only raw format.
Samuel Tai
You can try killing the VM directly: pgrep -fl bhyve will yield the bhyve VMs running, along with their VM IDs and names. Then kill -9 <bhyve process ID> will terminate the rogue VM.
Samuel Tai
OK, so the VM is actually down, but the web GUI hasn't caught up yet. Try rebooting to clear the GUI.
Chavell3
@Samuel Tai
yes rebooting the machine fixes the issue, for short term... but after some time the issue occurs again... so is there maybe a longterm solution that I can start boot the VM?
Samuel Tai
Look in /var/log/middlewared for any lines containing bhyve. There may be an indication there why this VM keeps crashing. Also, what guest is running in the VM, and how did you configure the VM in TrueNAS?
Chavell3
I wanted to install a windows machine with 2 Cores and 5Gb RAM.
My Server uses a 2 Cores(4 Threads) CPU and has 16GB of RAM.
If I look in your named log file I only find the following(for bhyve):
libvirt.libvirtError: internal error: Child process (/usr/sbin/bhyvectl --destroy --vm=1_CR_Client) unexpected exit status 1
Samuel Tai
Try setting these loader tunables to reflect your CPU:
hw.vmm.topology.cores_per_package=2
hw.vmm.topology.threads_per_core=2
These take effect on reboot. This lets bhyve know your CPU supports HyperThreading.
Chavell3
I found from the documentation, that at
/var/log/vm/vmname.
there should be some VM logs... but there aren't...
additionally if tried the command
but initially I got an output that some settings e.g.
$vm_enable
in rc.conf is not set...
so I set those commands, I found:
vm_enable="YES"
vm_dir="/mnt/data/"
vm_list=""
vm_delay="5"
But actually i don't no, where to set the "vm_dir" because I cannot found any information about that...
Another but, now that I set those commands in rd.conf the command
works...
but it does not list any vm's.
any idea how I can fix that?
Thanks
Samuel Tai
Actually, you should back out of your loader.conf changes; those are for CLI management of bhyve VMs that are incompatible with the GUI. For CLI status compatible with the GUI, you should use API calls via midclt call vm.query to get a list of defined VMs by ID and whether they're running or not.
Chavell3
and is there also a command to start or stop a vm via midctl?
I guess that could be enough for me...
Samuel Tai
Yes, midclt call vm.start <VM ID> and midclt call vm.stop <VM ID>. The IDs are the integer values listed in the "id" fields from the midclt call vm.query output.
Chavell3
yes, I found that too... but unfortunatly the vm is no stopable... :(
or I mean, it just not stops
Samuel Tai
Try midclt call vm.stop <VM ID> "force":true.
Chavell3
the return from your command was 4743
is midclt call vm.query representing the web state of the vm?
because if I run this command, the vm is still in running state.
