VM - Error
bar1
Hi everyone, wanted to play around with vm's a bit but i keep getting this error:
Error creating VM.
Error while creating the DISK device. [EINVAL] pool_dataset_create.volblocksize: Invalid choice: 16
guyp2k
Same issue I posted yesterday and spent a few hours debugging w/ out a solution. I assume you are running a nightly build and not the beta? Beta has no issues deploying VMs, seems the /usr/lib/python3/dist-packages/middlewared/plugins/*.py has changed since the beta.
Given it's a nightly issue may not receive any feedback from devs. In the interim if I find a solution I will post...
Other than the VM issue, been stable for me.
guyp2k
Seems to addressed in latest build:
TrueNAS-SCALE-21.07-MASTER-20210702-212917
