Virtualbox jail not running after virtualbox-ose-kmod updated
JoeB
Thanks, i have logged in, imported my machine, but i see this error:
SUP_IOCTL_COOKIE: Version mismatch. Requested: 0x280000 Min: 0x280000 Current: 0x260000
JWTech
Hi all,
as part of Feature #18630 Update to 2016Q4 Ports Tree is updated virtualbox-ose-kmod from 4.3.34 to 5.1.6:
current night build FreeNAS-9.10-MASTER-201612100422 (4d7d293)
[root@freenas3] ~# pkg info | grep -i virtualbox
virtualbox-ose-kmod-5.1.6 VirtualBox kernel module for FreeBSD
last stable FreeNAS-9.10.1-U4 (ec9a7d3)
[root@freenas] ~# pkg info |grep virtualbox
virtualbox-ose-kmod-4.3.34 VirtualBox kernel module for FreeBSD
Because of this update startup of Virtualbox VM in virtualbox jail fails and in "dmesg" output is error:
SUP_IOCTL_COOKIE: Version mismatch. Requested: 0x1a0007 Min: 0x1a0005 Current: 0x260000
Will you create new virtualbox jail template with 5.1.6 vbox version?
With 9.10 are many users using virtualbox jail and freenas 10 is not yet out.
If not, here are steps how to create new virtualbox jail yourself, for those, who want to still use virtualbox with current 9.10 version after update of virtualbox-ose-kmod to 5.1.6.
Before that, backup your machines in original virtualbox jail, so that you can move them to new jail after creation.
Steps to create new virtualbox jail
Jails -> Add Jail -> "virtualbox"
- this will create standart freebsd jail, do not choose old vbox template
jexec virtualbox
vi /usr/local/etc/pkg/repos/FreeBSD.conf
- url: "pkg+http://pkg.FreeBSD.org/freebsd:10:x86:64/latest",
+ url: "pkg+http://pkg.FreeBSD.org/freebsd:10:x86:64/quarterly",
pkg upgrade
pkg install virtualbox-ose phpvirtualbox apache24 mod_php56
adduser
Username: vbox
Full name: vbox
Uid (Leave empty for default): 1001
Login group [vbox]:
Login group is vbox. Invite vbox into other groups? []: vboxusers
Login class [default]:
Shell (sh csh tcsh git-shell nologin) [sh]:
Home directory [/home/vbox]:
Home directory permissions (Leave empty for default):
Use password-based authentication? [yes]:
Use an empty password? (yes/no) [no]:
Use a random password? (yes/no) [no]:
Enter password:VBox123
Enter password again:VBox123
Lock out the account after creation? [no]:
Username : vbox
Password : *****
Full Name : vbox
Uid : 1001
Class :
Groups : vbox vboxusers
Home : /home/vbox
Home Mode :
Shell : /bin/sh
Locked : no
OK? (yes/no): y
adduser: INFO: Successfully added (vbox) to the user database.
Add another user? (yes/no): no
Goodbye!
vi /etc/rc.conf
+ apache24_enable="YES"
+ vboxwebsrv_user="vbox"
+ vboxwebsrv_enable="YES"
service vboxwebsrv start
vi /usr/local/www/phpvirtualbox/config.php
- var $password = 'pass';
+ var $password = 'VBox123';
vi /usr/local/etc/apache24/httpd.conf
- DocumentRoot "/usr/local/www/apache24/data"
+ DocumentRoot "/usr/local/www/phpvirtualbox"
- <Directory "/usr/local/www/apache24/data">
+ <Directory "/usr/local/www/phpvirtualbox">
# In section <IfModule mime_module>, add after x-gzip type for php module:
AddType application/x-compress .Z
AddType application/x-gzip .gz .tgz
+ AddType application/x-httpd-php .php
+ AddType application/x-httpd-php-sources .phps
# workaround for older phpvirtualbox-5.0.5
vi /usr/local/www/phpvirtualbox/endpoints/api.php
- $response['data']['responseData']['phpvboxver'] = @constant('PHPVBOX_VER');
+ $response['data']['responseData']['phpvboxver'] = "5.1-0";
service apache24 start
ifconfig -a|grep inet
http://x.x.x.x
admin/admin
Enjoy!
I would create also template from this, but do now know how..
Kam
Edit: Didn't realize quarterly had just updated, causing this not to work any longer
You may want to make this into a proper how-to guide sometime, seeing as there won't likely be a fix for the old template, and I'm sure many would appreciate it.
Also, the 'vi' edits might be better switched (or added as an alternative) with replace/append commands, to speed things up, and simplify the process.
You could also use the 'ee' command for editing, as it's native to FreeBSD and considerably easier to work with than 'vi', or you could even add 'nano' to the packages installed on the jail, then continue editing with that due to ease-of-use.
sed -i '' 's/latest/quarterly/g' /usr/local/etc/pkg/repos/FreeBSD.conf
vi /etc/rc.conf
printf 'apache24_enable="YES"%s\nvboxwebsrv_user="vbox"%s\nvboxwebsrv_enable="YES"' >> /etc/rc.conf
sed -i '' "s/password = 'pass'/password = 'VBox123'/g" /usr/local/www/phpvirtualbox/config.php
sed -i '' 's@DocumentRoot "/usr/local/www/apache24/data"@DocumentRoot "/usr/local/www/phpvirtualbox"@g' /usr/local/etc/apache24/httpd.conf sed -i '' 's@Directory "/usr/local/www/apache24/data"@Directory "/usr/local/www/phpvirtualbox"@g' /usr/local/etc/apache24/httpd.conf
and so on.
You should also be able to one-line the entire 'adduser' step as well.
scatolino
I thought I did too, but I double checked and I didn't miss that part. From what I can see, it looks like the package was updated on the 3rd to 5.1.12. Currently I'm trying to downgrade to 5.1.6 so that it matches up. I also looked into updated the kernel module, but that'd have to be done outside the Jail, and I don't want to mess with that.
Same here. I can't find a way to downgrade to 5.1.6... I'm stuck. The how-to is not working anymore.
jidckii
Hi.
It seems the problem for more than a year.
There is still no Virtualbox 5.1.6 template?
There is a bug on this issue on the tracker?
Kam
There were more bugs filled where developers explained that official virtualbox template is dessuported and this issue will not be fixed.
We can only create new virtualbox jail ourself, if we have correct virtualbox version, which matches modules in host.
ArgaWoW
Do you have a correct version. I am searching for it
Gesendet von meinem LG-H850 mit Tapatalk
JoeB
Is there anything that can be done about this? Right now, my VM is bricked and there is no way I can find to allow me access to the VM.
I've reinstalled as per post 1, but my existing VMs cannot be restarted.
Looks like reinstalling/configuring the VM'ed OS'es seems to be the only way, but really... bricking the user's VMs is just not a nice thing for the devs to do, is it?
What's the point of maintaining VM snapshots etc if the devs are just going to brick the system anyway, and from what i can see, without notice. If i'd known that the last update would render the system useless, i'd not have bothered updating. This is now the 2nd time in a year that a Freenas update has <censored> up the system.
jidckii
I understand in freenas 10 will default bhyve.
Therefore, in support of virtualbox does not make sense.
a manual on the current I faced here with a problem:
what's wrong ?
here there are instructions on how to create a template:
http://doc.freenas.org/9.10/jails.html#managing-jail-templates
can someone share a working version ?
noobnas
I found that I have older virtualbox package still in a cache on one machine
root@virtualbox:/var/cache/pkg # ls -la /var/cache/pkg/virtualbox-ose-5.1.6_1-b81cf4010c.txz
-rw-r--r-- 1 root wheel 42999872 Dec 15 07:53 /var/cache/pkg/virtualbox-ose-5.1.6_1-b81cf4010c.txz
is it possible to copy it to jail on other machine and install it from file? with which "pkg" command?
EDIT: thanks for example with ports, I will try it.
Can you please post the txz file somewhere for us to download?
noobnas
j0achim
After a ton of searching I have manged to find both virtualbox-ose 5.1.6 and virtualbox-ose-kmod 5.1.6, now however it appears that libvncserver0 is also an issue.
Does anyone have a copy of libvncserver-0.9.10.txz ?
root@virtualbox:/usr/lib # pkg info | grep virtualbox
phpvirtualbox-5.0.5            AJAX Web Interface for VirtualBox
virtualbox-ose-5.1.6_1         General-purpose full virtualizer for x86 hardware
Now when starting a VM i get the message "Could not find the VirtualBox Remote Desktop Extension library".
VirtualBox VM 5.1.6 r110634 freebsd.amd64 (Dec 15 2016 06:00:01) release log
00:00:00.029511 Log opened 2017-02-09T18:01:52.350198000Z
00:00:00.029512 Build Type: release
00:00:00.029521 OS Product: FreeBSD
00:00:00.029523 OS Release: 10.3-RELEASE
00:00:00.029526 OS Version: FreeBSD 10.3-STABLE #0 r295946+1805185(9.10.2-STABLE): Wed Jan 11 17:12:42 UTC 2017     root@gauntlet:/freenas-9.10-releng/_BE/objs/freenas-9.10-releng/_BE/os/sys/FreeNAS.amd64
00:00:00.029542 Host RAM: 32679MB total, 2898MB available
00:00:00.029544 Executable: /usr/local/lib/virtualbox/VBoxHeadless
00:00:00.029544 Process ID: 83251
00:00:00.029545 Package type: BSD_64BITS_GENERIC (OSE)
00:00:00.040273 Installed Extension Packs:
00:00:00.040288   Oracle VM VirtualBox Extension Pack (Version: 5.1.6 r110634; VRDE Module: VBoxVRDP unusable because of 'Failed to locate the main module ('VBoxPuelMain')')
00:00:00.040296   VNC (Version: 5.1.6 r110634; VRDE Module: VBoxVNC)
00:00:00.040728 Console: Machine state changed to 'Starting'
00:00:00.041246 rtldrNativeLoad: dlopen('/usr/local/lib/virtualbox/ExtensionPacks/VNC/freebsd.amd64/VBoxVNC.so', RTLD_NOW | RTLD_LOCAL) failed: Shared object "libvncserver.so.0" not found, required by "VBoxVNC.so"
00:00:00.041265 VRDE: Error loading the library '/usr/local/lib/virtualbox/ExtensionPacks/VNC/freebsd.amd64/VBoxVNC.so': Shared object "libvncserver.so.0" not found, required by "VBoxVNC.so" (VERR_FILE_NOT_FOUND)
00:00:00.041277 VRDE: Failed: (VERR_FILE_NOT_FOUND): Could not find the VirtualBox Remote Desktop Extension library
00:00:00.041299 ERROR [COM]: aRC=NS_ERROR_FAILURE (0x80004005) aIID={872da645-4a9b-1727-bee2-5585105b9eed} aComponent={ConsoleWrap} aText={Could not find the VirtualBox Remote Desktop Extension library}, preserve=false aResultDetail=0
00:00:00.041709 Console: Machine state changed to 'PoweredOff'
00:00:00.062018 Power up failed (vrc=VERR_FILE_NOT_FOUND, rc=NS_ERROR_FAILURE (0X80004005))
root@virtualbox:/usr/lib # pkg info | grep vnc
libvncserver-0.9.11            Provide an easy API to a custom vnc server
And finally.
root@virtualbox:/usr/lib # vboxmanage list extpacks
Extension Packs: 2
Pack no. 0:   Oracle VM VirtualBox Extension Pack
Version:      5.1.6
Revision:     110634
Edition:
Description:  USB 2.0 and USB 3.0 Host Controller, Host Webcam, VirtualBox RDP, PXE ROM, Disk Encryption.
Usable:       false
Why unusable: Failed to locate the main module ('VBoxPuelMain')
Pack no. 1:   VNC
Version:      5.1.6
Revision:     110634
Edition:
Description:  VNC plugin module
Usable:       true
Why unusable:
j0achim
Installed libvncserver 0.9.9 and now I have VirtualBox running on FreeNAS-9.10.2-U1 (86c7ef5)
root@virtualbox:/home/vbox # pkg info | grep vnc
libvncserver-0.9.9_11          Provide an easy API to a custom vnc server
root@virtualbox:/home/vbox # pkg info | grep virtualbox
ArgaWoW
can you do a "step by step how to" for the installation. Me really a noob on these things :/
Thanks in advance for your time
stallione
[/code]
Hello j0achim,
Could you please upload virtualbox-ose-kmod 5.1.6 and libvncserver-0.9.10.txz somewhere? I can provide an ftp site if you have the files or email me the files to rajeshchacko1-at-gmail;
Thanks!
j0achim
Hi guys, sure.
Firts off I started going through the guide as it tells you.
Remove virtualbox-ose, virtualbox-ose-kmod and libvncserver. (pkg remove ....)
I then start by installing libvncserver-0.9.9 (this wants to install openssl you can either accept this or force the installation, we wont actually need it)
  • pkg add libvncserver-0.9.9_5.txz
Next I installed virtualbox-ose and virtualbox-ose-kmod one of which have to be installed before another, it will tell you so you can't mistakely do wrong.
  • pkg add virtualbox-ose-5.1.6_1-b81cf4010c.txz
  • pkg add virtualbox-ose-kmod-5.1.6.txz
Copy of virtualbox-ose, virtualbox-ose-kmod and libvncserver here.
Done and enjoy!
m0nkey_
Word of warning to all, only install this 'mod' if you are comfortable in the knowledge that the software may have been modified in some way (not that I am saying it is).
@j0achim, I recommend you link to the source code and provide instructions on how to compile it, instead of providing unverified links.
VirtualBox is unsupported as of 9.10.2-U1. Bhyve is available and is the hypervisor of choice within FreeNAS.
