Hi Guys,
I recently tried the php virtual box jail to get lubuntu or debian working as jail. Im currently on Freenas 9.10.2-U1. By default, when I tried to create Vbox jail, the template was missing. Thus, I had to dig Freenas download resource and add the link to the template screen and then get my jail setup. I tried both the vbox templates. Since release 9.10 was not showing the links I had to get them from 9.2 folder.
I tried these two:
http://download.freenas.org/jails/9.2/x64/freenas-virtualbox-4.3.12.tgz
http://download.freenas.org/jails/9.2/x64/vboxtemplate.tgz
The jail gets setup pretty nicely, and I am able to even open the vbox administration page in my browser. So to install a vm, i go through the setup wizard, do the needful and load the iso image of debian. However, the moment I press start to run the VM, I get error below:
To circumvent any ambiguity, I tried two versions of vbox templates as above, and I have also tried multiple variants of Linux such as debian x86, lubuntu x86 and even lubuntu x64.
For all times, I get the same error as below. Can anyone advice what I am missing?
I tried these two:
Exception Object ( [message:protected] => The virtual machine 'Debian' has terminated unexpectedly during startup with exit code 1 [string:Exception:private] => [code:protected] => 0 [file:protected] => /usr/local/www/phpvirtualbox/lib/vboxconnector.php [line:protected] => 2382 [trace:Exception:private] => Array ( [0] => Array ( => /usr/local/www/phpvirtualbox/lib/vboxconnector.php [line] => 928 [function] => remote_progressGet [class] => vboxconnector [type] => -> [args] => Array ( [0] => Array ( [progress] => 7f6b8a5f16f7d098-0000000000000136 [_persist] => Array ( [vboxHandle] => 7f6b8a5f16f7d098-0000000000000134 ) [fn] => progressGet ) ) ) [1] => Array ( => /usr/local/www/phpvirtualbox/lib/ajax.php [line] => 309 [function] => __call [class] => vboxconnector [type] => -> [args] => Array ( [0] => progressGet [1] => Array ( [0] => Array ( [progress] => 7f6b8a5f16f7d098-0000000000000136 [_persist] => Array ( [vboxHandle] => 7f6b8a5f16f7d098-0000000000000134 ) [fn] => progressGet ) [1] => Array ( [0] => Array ( [data] => Array ( [responseData] => Array ( [progress] => 7f6b8a5f16f7d098-0000000000000136 [info] => Array ( [completed] => 1 [canceled] => [description] => Starting VM [operationDescription] => Creating process for virtual machine "Debian" (headless) [timeRemaining] => Array ( ) [timeElapsed] => Array ( [days] => 17220 [hours] => 2 [minutes] => 41 [seconds] => 9 ) [percent] => 0 ) ) [success] => 1 [key] => 53474945cfd7ac0bf8114767c209c2a6 ) [errors] => Array ( ) [persist] => Array ( ) [messages] => Array ( ) ) ) ) ) ) [2] => Array ( => /usr/local/www/phpvirtualbox/lib/ajax.php [line] => 309 [function] => progressGet [class] => vboxconnector [type] => -> [args] => Array ( [0] => Array ( [progress] => 7f6b8a5f16f7d098-0000000000000136 [_persist] => Array ( [vboxHandle] => 7f6b8a5f16f7d098-0000000000000134 ) [fn] => progressGet ) [1] => Array ( [0] => Array ( [data] => Array ( [responseData] => Array ( [progress] => 7f6b8a5f16f7d098-0000000000000136 [info] => Array ( [completed] => 1 [canceled] => [description] => Starting VM [operationDescription] => Creating process for virtual machine "Debian" (headless) [timeRemaining] => Array ( ) [timeElapsed] => Array ( [days] => 17220 [hours] => 2 [minutes] => 41 [seconds] => 9 ) [percent] => 0 ) ) [success] => 1 [key] => 53474945cfd7ac0bf8114767c209c2a6 ) [errors] => Array ( ) [persist] => Array ( ) [messages] => Array ( ) ) ) ) ) ) [previous:Exception:private] => )
