Virtual Firewall running on Truenas 13.0 U2
paohagan
I have a virtual firewall running on Truenas and I changed the NIC associated with the virtual firewall for the WAN port. Unfortunately when I changed the WAN port it was then sharing the Webinterface with Truenas. I can still get internet access, the firewall web interface and the Truenas interface, however I can no longer login to the Truenas interface to change the Webinterface port for Truenas to the free ethernet connection that I have. It appears that the shared WAN/Truenas interface has caused the Truenas logon interface to fail. I am running 2FA which seems to add to the issue. How can I get to the shell if I cannot log into the web interface anymore? I have tried a few options by adding a keyboard to Truenas but I dont see any easy way to change the web interface port on Truenas 13.0 U2 from the boot menu.
Any help is appreciated.
paohagan
I have resolved this issue myself by using the command "etc/netcli". The interface menu was then available to reset the web interface network port.
