zeno
- Sep 12, 2022
Hi, peeps!
I'm experiencing an issue with a transfer of files from a backup drive to my ZFS pool in SCALE.
The directory tree is like this:
I have created a user with the same username as
Does anyone know how to make it visible? I'm trying to go through it so that I'm sure my backups are there, before I wipe all the data on the fifth drive, reorganize the data inside
Thanks
myPool/ ├─ backups/ │ ├─ myUser/ │ │ ├─ myPC/ │ │ │ ├─ backups/ # folder I've transferred from fifth drive │ │ ├─ myLaptop/
myUser
, in order to be able to mount the myUser
directory on my desktop PC through NFS. I transferred it using the command line and rsync -rzP
from a fifth drive I'm planning to use as backup drive. However, when accessing the NFS share from my desktop, the backups
folder isn't inside the myPC
folder, even though when I go to check on my home-server, it is inside the drive.Does anyone know how to make it visible? I'm trying to go through it so that I'm sure my backups are there, before I wipe all the data on the fifth drive, reorganize the data inside
backups
, and set up an rsync
cron-job inside TrueNAS to make periodical backups to said drive.Thanks
