vfs options for async and acls
I am looking for better information on vfs options for async IO and acls.
In the documentation for freenas 11.1, there are a two options for aio : aio_pthread and aio_fork. The first one seems to be gone in the latest freenas I installed yesterday. Can anyone explain the difference between the two and which one I should use in a mac/pc environment ?
In the same documentation, there are a bunch of options for acls : zfsacl, fake_acls and acl_xattr. Can zfsacl and acl_xattr be used together, which one should I use in a mac/pc environment ? Can anyone explain a little bit better than the official documentation what they are and what they do ?
Thank you,
anodos
Sambassador
Thank you,
aio_pthread doesn't do anything on freebsd. There's no reason to enable aio vfs modules. Pthread-based AIO is now baked into samba, if you want to use it just adjust your aio read/write size. As far as ACLs go, use zfsacl. It's your only option. There's no reason to use anything else.
seanm
Happy I found this thread. For others reading, this list of useless/obsolete options may be helpful: https://redmine.ixsystems.com/issues/58824
