Default vfs objects not enabled by default
Agent92
When reading the documentation about the vfs objects zfs_space and zfsacl it says "Enabled by default" on both. But when I create a new SMB share they are not enabled by default. The only vfs objects that are enabled are ixnas and streams_xattr. What gives? A bug? Error in documentation?
The documentation: https://www.ixsystems.com/documentation/freenas/11.3-U1/sharing.html
I'm running FreeNAS 11.3-U1.
anodos
Sambassador
Nooms
How to add vfs objects to truesnas 12
I need it for Final Cut Pro X libraries
