very slow administrative GUI -help wanted
Hi
I upgrade my ram from 4gb to 8 gb and did a new install to a new usb 8gb whith 9.3 had 9.something before.
My gui is now very slow but reading and writing files is quick, no differans there. ? ide
anyone to help me!
do i reinstall or what, it seems i have to vait forever for the Gui interface can it be the usb stick being slower or have somthing gone bad!
Can this be my trouble?
Yes, since FreeNAS 9.3 uses gpt (and ZFS too) that's a non-starter for you. You'll need newer hardware if you want to use 9.3.
but it boots and i can mount my volumes but if alert is flashing in the GUI it takes 20 seconds just to open a little directory
i did not save my old 4gb usb I installed 9.3 from it
mu spec is 8029Gb of ram Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz 6 x sata 1 x ide
if i mount the nas to my linux before i logg in to GUI i open a dir and there open a picture itś done in 2 sec any idea´s /ivar
this prob has been up for tree long days now and nobody wants to help? I try a new install of 9.3 new usb new download . To be continued....
by the way 9.3 thats a SAAB :smile:
