Used SAS drives...No I/O?? Locked?
AgentZero
I bought a few used SAS drives - Hitachi DKR2H-K45SS 450GB SAS. I cannot for the life of me get any I/O on these drives. They show up in camcontrol, etc, but can't even dd to them - the other Hitachi (different part number) drives are fine...
<HITACHI HUS153030VLS300 A4C2> at scbus0 target 26 lun 0 (pass6,da6)
<HITACHI HUS153030VLS300 A4C2> at scbus0 target 27 lun 0 (pass7,da7)
<ATA TOSHIBA DT01ACA2 ABB0> at scbus1 target 3 lun 0 (pass8,da8)
<ATA TOSHIBA DT01ACA2 ABB0> at scbus1 target 4 lun 0 (pass9,da9)
<ATA TOSHIBA DT01ACA2 ABB0> at scbus1 target 5 lun 0 (pass10,da10)
<HITACHI DKR2H-K450SS D017> at scbus1 target 6 lun 0 (pass11,da11) <<<
<HITACHI DKR2H-K450SS D017> at scbus1 target 7 lun 0 (pass12,da12) <<<
Everything that tries to write, wipe, format, partition....anything on these drives comes back with an I/O error.
[root@ZFS] ~# dd if=/dev/zero of=/dev/da11
dd: /dev/da11: Invalid argument
1+0 records in
0+0 records out
0 bytes transferred in 0.000172 secs (0 bytes/sec)
I've tried booting into several things - DBAN, PMagic, Windows...nothing can touch these drives. What am I missing? The only thing I can think of is these drives are specific to the Hitachi AMS2X00 SAN and somehow locked in firmware...I'm at a loss.
Brief hardware: Supermicro X9SRL; 2x M1015 IT mode
image.axd
I don't know what to say. Often if people turn off certain things like auto-spinup and such you have to have specific hardware to recover from that situation.
I *never* buy hard drives from anyone but my closest friends. No clue how you bought yours, but if you bought it from a friend he should be able to help you recover. If you didn't, well, either do an RMA or chalk this up to a lesson learned.
AgentZero
Audibly, auto-spinup is turned on as they do spin up to 15K, but I'm not sure that there isn't something else that is somehow disabled in firmware or hardware locked.
Agreed - this was from a reputable shop I have dealt with in the past - already have an RMA, but would have preferred to avoid all this nonsense of returning, etc.
jyonke
What was the result of this? I just picked up a couple used 15K4150's and they are combined with a IBM M5015. In the WEBIOS I get an unsupported flag. I don't think it is strictly a defective drive as I have 9 of these from different vendors and they all show the exact same thing.
[root@localhost:/opt/lsi/storcli] ./storcli /c0/e252/s0 show
Controller = 0
Status = Success
Description = Show Drive Information Succeeded.
Drive Information :
EID:Slt DID State  DG       Size Intf Med SED PI SeSz Model            Sp
252:0    14 UGUnsp -  408.850 GB SAS  HDD N   N  512B DKR2H-K450SS     U
EID-Enclosure Device ID|Slt-Slot No.|DID-Device ID|DG-DriveGroup
DHS-Dedicated Hot Spare|UGood-Unconfigured Good|GHS-Global Hotspare
UBad-Unconfigured Bad|Onln-Online|Offln-Offline|Intf-Interface
Med-Media Type|SED-Self Encryptive Drive|PI-Protection Info
SeSz-Sector Size|Sp-Spun|U-Up|D-Down|T-Transition|F-Foreign
UGUnsp-Unsupported|UGShld-UnConfigured shielded|HSPShld-Hotspare shielded
CFShld-Configured shielded|Cpybck-CopyBack|CBShld-Copyback Shielded
[root@localhost:/opt/lsi/storcli] ./storcli -PDList -aALL
Adapter #0
Enclosure Device ID: 252
Slot Number: 0
Enclosure position: 0
Device Id: 14
WWN: 5000CCA0094C9737
Sequence Number: 1
Media Error Count: 0
Other Error Count: 0
Predictive Failure Count: 0
Last Predictive Failure Event Seq Number: 0
PD Type: SAS
Raw Size: 410.281 GB [0x33490000 Sectors]
Non Coerced Size: 409.781 GB [0x33390000 Sectors]
Coerced Size: 408.850 GB [0x331b3800 Sectors]
Sector Size: 512
Firmware state: Unconfigured(good), Spun Up
Device Firmware Level: D017
Shield Counter: 0
Successful diagnostics completion on :  N/A
SAS Address(0): 0x5000cca0094c9735
SAS Address(1): 0x0
Connected Port Number: 0(path0)
Inquiry Data: HITACHI DKR2H-K450SS    D017JMWB3TDD
FDE Capable: Not Capable
FDE Enable: Disable
Secured: Unsecured
Locked: Unlocked
Needs EKM Attention: No
Foreign State: None
Device Speed: 3.0Gb/s
Link Speed: 3.0Gb/s
Media Type: Hard Disk Device
Drive:  Not Supported
Drive Temperature : N/A
PI Eligibility:  No
Drive is formatted for PI information:  No
PI: No PI
Port-0 :
Port status: Active
Port's Linkspeed: 3.0Gb/s
Port-1 :
Port status: Active
Port's Linkspeed: Unknown
Drive has flagged a S.M.A.R.T alert : No
AgentZero
I ended up RMAing all of them - as CJ points out, recommend only buying from reputable if not new, so there were no questions asked about the RMA.
I have no idea what happened with that batch. Every other drive I used has not been a problem.
jyonke
Were yours all still under warranty? These things are not new by any means, haha. While I totally agree with CJ, the data on these is not going to be valuable and is strictly for a lab environment. All other servers at home that have invaluable data are on new drives, that are redundant and data is backed up off site.
tvsjr
If these drives came from a SAN, they're probably formatted for 520- or 528-byte sectors. They probably also will have write cache disabled by default.
To reformat them to 512-byte, try something like: http://pissedoffadmins.com/general/unsupported-sector-size-520.html
sg_format is the tool you'll want
For the write cache, you'll need to add a post-init script through the GUI. Look through my previous posts and you'll find the simple little script I created.
AgentZero
OMG Thank you! I picked up some Hitachi SLC SAS SSDs which came out of a 3PAR system. Was about to throw something....sure enough "Unsupported sector size 520". Running setblocksize now. I'm sure that this would have fixed my previous issues.
