Netapp 4486 & LSI 9200-8e Issues > 2tb
brad87
My Hardware
Netapp 4486 disk shelf with 2x IOM6 (One cabled to Freenas host via QSFP - SFF8088 cable)
LSI 9200-8e (flashed with IT firmware on Freenas host)
Freenas Host: Supermicro X9 with 5640 xeons, 72gb ram
My Issue
When attempting to load in a caddy with 4/6 tb drives, I am getting the following in the dmesg log of the freenas host:
da1 at mps0 bus 0 scbus0 target 8 lun 2
da1: <HITACHI HUS724040ALE64DB NA01> Fixed Direct Access SPC-3 SCSI device
da0 at mps0 bus 0 scbus0 target 8 lun 1
da1: Serial Number PAGU83ES
da0: <HITACHI HUS724040ALE64DB NA01> Fixed Direct Access SPC-3 SCSI device
da0: Serial Number PAGU82VS
da0: 600.000MB/s transfersda1: 600.000MB/s transfers
da1: Command Queueing enabled
da1: Attempt to query device size failed: ABORTED COMMAND, Internal target failure
da0: Command Queueing enabled
da0: Attempt to query device size failed: ABORTED COMMAND, Internal target failure
As a test I have populated a caddy with a single 1tb drive, and did not have this problem, which makes me really nervous.:
da25 at mps0 bus 0 scbus0 target 19 lun 1
da25: <HITACHI HUS724040ALE64DB NA01> Fixed Direct Access SPC-3 SCSI device
da25: Serial Number PAGS6N6S
da25: 600.000MB/s transfers
da25: Command Queueing enabled
da25: 953869MB (1953525168 512 byte sectors)
root@constellation:~ # camcontrol devlist
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 8 lun 0 (pass1)
<HITACHI HUS724040ALE64DB NA01>    at scbus0 target 8 lun 1 (da0,pass2)
<HITACHI HUS724040ALE64DB NA01>    at scbus0 target 8 lun 2 (da1,pass20)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 9 lun 0 (pass3)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 10 lun 0 (pass4)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 11 lun 0 (pass5)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 12 lun 0 (pass6)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 13 lun 0 (pass7)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 14 lun 0 (pass8)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 15 lun 0 (pass9)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 16 lun 0 (pass10)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 17 lun 0 (pass11)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 18 lun 0 (pass12)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 19 lun 0 (pass13)
<HITACHI HUS724040ALE64DB NA01>    at scbus0 target 19 lun 1 (da25,pass51)
<NETAPP DS448IOM6 0173>            at scbus0 target 20 lun 0 (pass14,ses0)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 21 lun 0 (pass15)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 22 lun 0 (pass16)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 23 lun 0 (pass17)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 24 lun 0 (pass18)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 25 lun 0 (pass19)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 27 lun 0 (pass21)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 28 lun 0 (pass22)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 29 lun 0 (pass23)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 30 lun 0 (pass24)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 31 lun 0 (pass25)
<MARVELL LUIGI_V2_STSB_DB 2015>    at scbus0 target 32 lun 0 (pass26)
<DOGFISH 30G Q0707A>               at scbus2 target 0 lun 0 (pass27,ada0)
<HPT DISK 0_0 4.00>                at scbus6 target 0 lun 0 (pass28,da2)
<HPT DISK 0_1 4.00>                at scbus6 target 1 lun 0 (pass29,da3)
<HPT DISK 0_2 4.00>                at scbus6 target 2 lun 0 (pass30,da4)
<HPT DISK 0_3 4.00>                at scbus6 target 3 lun 0 (pass31,da5)
<HPT DISK 0_4 4.00>                at scbus6 target 4 lun 0 (pass32,da6)
<HPT DISK 0_5 4.00>                at scbus6 target 5 lun 0 (pass33,da7)
<HPT DISK 0_6 4.00>                at scbus6 target 6 lun 0 (pass34,da8)
<HPT DISK 0_7 4.00>                at scbus6 target 7 lun 0 (pass35,da9)
<HPT DISK 0_8 4.00>                at scbus6 target 8 lun 0 (pass36,da10)
<HPT DISK 0_9 4.00>                at scbus6 target 9 lun 0 (pass37,da11)
<HPT DISK 0_10 4.00>               at scbus6 target 10 lun 0 (pass38,da12)
<HPT DISK 0_11 4.00>               at scbus6 target 11 lun 0 (pass39,da13)
<HPT DISK 0_12 4.00>               at scbus6 target 12 lun 0 (pass40,da14)
<HPT DISK 0_13 4.00>               at scbus6 target 13 lun 0 (pass41,da15)
<HPT DISK 0_14 4.00>               at scbus6 target 14 lun 0 (pass42,da16)
<HPT DISK 0_15 4.00>               at scbus6 target 15 lun 0 (pass43,da17)
<HPT DISK 0_16 4.00>               at scbus6 target 16 lun 0 (pass44,da18)
<HPT DISK 0_17 4.00>               at scbus6 target 17 lun 0 (pass45,da19)
<HPT DISK 0_18 4.00>               at scbus6 target 18 lun 0 (pass46,da20)
<HPT DISK 0_19 4.00>               at scbus6 target 19 lun 0 (pass47,da21)
<HPT DISK 0_20 4.00>               at scbus6 target 20 lun 0 (pass48,da22)
<HPT DISK 0_21 4.00>               at scbus6 target 21 lun 0 (pass49,da23)
<HPT DISK 0_22 4.00>               at scbus6 target 22 lun 0 (pass50,da24)
brad87
These drives were not from a netapp, I sourced them from work where they were previously in some sort of ceph cluster. The last thing that I had done to them was run badblocks destructive test.
here is what im getting from diskinfo, does this output indicate that these need to be formatted?
root@constellation:~ # diskinfo -v da1
diskinfo: da1: ioctl(DIOCGMEDIASIZE) failed, probably not a disk.
brad87
Furthermore, this is the output of geom disk list, looks lik eit already has 512 sectors
Geom name: da0
Providers:
1. Name: da0
Mediasize: 0 (0B)
Sectorsize: 512
Mode: r0w0e0
descr: HITACHI HUS724040ALE64DB
lunid: 5000cca22bcb7ba7
ident: PAGU82VS
rotationrate: unknown
fwsectors: 0
fwheads: 0
Geom name: da1
Providers:
1. Name: da1
Mediasize: 0 (0B)
Sectorsize: 512
Mode: r0w0e0
lunid: 5000cca22bcb7bb9
ident: PAGU83ES
fwsectors: 0
fwheads: 0
I am not sure. Mediasize being 0 is a bad thing. Is it possible those drives have a jumper settings that they don't spin up until explicitly told to do so?
brad87
There doesnt appear to be any jumpers at all on the drives, also I am using a combination of hitachi / and seagate drives for this testing. The WD 1tb spun up and works, its just the larger drives that are giving me trouble.
That is an older controller based on the LSI 2008 chipset. That might be part of the problem. An LSI 9207-8e is based on the 3008 chipset, and those are ~= $50 on eBay. Do you have something else with a newer HBA where you could try the drives to confirm that they are working? It does seem unlikely that they would all be bad though.
brad87
ill order a newer HBA and see if that resolves anything. I know for sure that the drives are fine as they work when I hook them up to my Highpoint card
That is pretty close to a definitive answer there.
brad87
Im just hoping that the issue doesnt lie in the disk shelf, or the caddies, or the IOM6 ... The netapp site and firmware upgrade process is a little locked down to homelabbers.. I dont know where to start investigating firmware updates for the shelf
I am assuming those are 3.5" drives. I have seen people reuse NetApp shelves, but I haven't done it myself. I have some external drives in HP 2700 (2.5" x 25) and HP D2600 (3.5" x 12) shelves, and those work great. They are also very inexpensive on eBay. I am sure there are plenty of other options as well. The HP ones are the only ones with which I have firsthand knowledge.
brad87
I was mistaken when I said earlier that the drives function fine with other backplanes. WHen I moved the adapter into my linux host, it did not work there either. I hava also tried to use them with my RocketRaid card and an adaptec HBA, and am facing similar messages in dmesg, about 0 512 byte sectors
Perhaps it is an issue with the firmware on the drives, but I don't have any suggestions for addressing that.
brad87
the last thing I did with these drives was run badblocks -wsv -b 4096 (on a machine at work). Could this have anything to do with my issue
I don't think so, but I am not really sure. I would try putting them back into a machine where they did work and see if they still do.
brad87
The more I delve into this , the more I am thinking this may have something to do with SAS Pin 3, as the drives dont seem to spin up in the netapp enclosure at all. Seems to be a common trend among these drives. I have ordered some Kapton tape to test this theory
