Used Fibre Channel card - which to buy?
poldas
I would like to change my gigabit ethernet to fibre channel. Can you recommend which CF cards are supported by FreeNAS?
Dice
mav@
Most of QLogic FC cards should work with FreeNAS. There is no official FC support in FreeNAS, but there are guides how to make it work, using code present in FreeBSD on which FreeNAS is based. It is recommended to use at least 4Gbps adapters, which are 24xx series and higher, while 8Gbps 25xx are preferable.
