I bought four WD Elements 8TB USB3 HDDs to create a raidz1 pool for backups. Thats working fine and is copying files without problems for 24 hours but it is just way to slow. I found out that only USB2 speed is used and all 4 drives share the same port because I used a 4-port-usb3-hub to connect them because my X10SLL-F Mainboard only got 1 external USB3 port.
The logs are showing this:
"usbdevs" to get more information seems not to be shipped with FreeNAS.
Isn't FreeNAS able to use USB3 by default?
Is there a way to find out why only USB2 is used and not USB3?
How to find out if the USB Controller on the mainboard, the USB-Hub or the USB-HDDs is causing the USB3 to fall back to USB2 mode?
Mar 7 17:37:05 BM-Homeserver ugen1.5: <Generic 4-Port USB 2.0 Hub> at usbus1
Mar 7 17:37:05 BM-Homeserver uhub5 on uhub2
Mar 7 17:37:05 BM-Homeserver uhub5: <Generic 4-Port USB 2.0 Hub, class 9/0, rev 2.10/1.21, addr 5> on usbus1
Mar 7 17:37:05 BM-Homeserver uhub5: MTT enabled
Mar 7 17:37:06 BM-Homeserver uhub5: 4 ports with 4 removable, self powered
Mar 7 17:37:22 BM-Homeserver ugen1.6: <Western Digital Elements 25A3> at usbus1
Mar 7 17:37:22 BM-Homeserver umass0 on uhub5
Mar 7 17:37:22 BM-Homeserver umass0: <Western Digital Elements 25A3, class 0/0, rev 2.10/10.21, addr 6> on usbus1
Mar 7 17:37:22 BM-Homeserver umass0: SCSI over Bulk-Only; quirks = 0xc101
Mar 7 17:37:22 BM-Homeserver umass0:9:0: Attached to scbus9
Mar 7 17:37:26 BM-Homeserver ugen1.7: <Western Digital Elements 25A3> at usbus1
Mar 7 17:37:26 BM-Homeserver umass1 on uhub5
Mar 7 17:37:26 BM-Homeserver umass1: <Western Digital Elements 25A3, class 0/0, rev 2.10/10.21, addr 7> on usbus1
Mar 7 17:37:26 BM-Homeserver umass1: SCSI over Bulk-Only; quirks = 0xc101
Mar 7 17:37:26 BM-Homeserver umass1:10:1: Attached to scbus10
Mar 7 17:37:30 BM-Homeserver ugen1.8: <Western Digital Elements 25A3> at usbus1
Mar 7 17:37:30 BM-Homeserver umass2 on uhub5
Mar 7 17:37:30 BM-Homeserver umass2: <Western Digital Elements 25A3, class 0/0, rev 2.10/10.21, addr 8> on usbus1
Mar 7 17:37:30 BM-Homeserver umass2: SCSI over Bulk-Only; quirks = 0xc101
Mar 7 17:37:30 BM-Homeserver umass2:11:2: Attached to scbus11
Mar 7 17:37:34 BM-Homeserver ugen1.9: <Western Digital Elements 25A3> at usbus1
Mar 7 17:37:34 BM-Homeserver umass3 on uhub5
Mar 7 17:37:34 BM-Homeserver umass3: <Western Digital Elements 25A3, class 0/0, rev 2.10/10.21, addr 9> on usbus1
Mar 7 17:37:34 BM-Homeserver umass3: SCSI over Bulk-Only; quirks = 0xc101
Mar 7 17:37:34 BM-Homeserver umass3:12:3: Attached to scbus12
Mar 7 17:37:39 BM-Homeserver da4 at umass-sim0 bus 0 scbus9 target 0 lun 0
Mar 7 17:37:39 BM-Homeserver da4: <WD Elements 25A3 1021> Fixed Direct Access SPC-4 SCSI device
Mar 7 17:37:39 BM-Homeserver da4: Serial Number XXXXXXA
Mar 7 17:37:39 BM-Homeserver da4: 40.000MB/s transfers
Mar 7 17:37:39 BM-Homeserver da4: 7630853MB (15627986944 512 byte sectors)
Mar 7 17:37:39 BM-Homeserver da4: quirks=0x2<NO_6_BYTE>
Mar 7 17:37:43 BM-Homeserver da5 at umass-sim1 bus 1 scbus10 target 0 lun 0
Mar 7 17:37:43 BM-Homeserver da5: <WD Elements 25A3 1021> Fixed Direct Access SPC-4 SCSI device
Mar 7 17:37:43 BM-Homeserver da5: Serial Number XXXXXX
Mar 7 17:37:43 BM-Homeserver da5: 40.000MB/s transfers
Mar 7 17:37:43 BM-Homeserver da5: 7630853MB (15627986944 512 byte sectors)
Mar 7 17:37:43 BM-Homeserver da5: quirks=0x2<NO_6_BYTE>
Mar 7 17:37:47 BM-Homeserver da6 at umass-sim2 bus 2 scbus11 target 0 lun 0
Mar 7 17:37:47 BM-Homeserver da6: <WD Elements 25A3 1021> Fixed Direct Access SPC-4 SCSI device
Mar 7 17:37:47 BM-Homeserver da6: Serial Number XXXXXX
Mar 7 17:37:47 BM-Homeserver da6: 40.000MB/s transfers
Mar 7 17:37:47 BM-Homeserver da6: 7630853MB (15627986944 512 byte sectors)
Mar 7 17:37:47 BM-Homeserver da6: quirks=0x2<NO_6_BYTE>
Mar 7 17:37:51 BM-Homeserver da7 at umass-sim3 bus 3 scbus12 target 0 lun 0
Mar 7 17:37:51 BM-Homeserver da7: <WD Elements 25A3 1021> Fixed Direct Access SPC-4 SCSI device
Mar 7 17:37:51 BM-Homeserver da7: Serial Number XXXXXX
Mar 7 17:37:51 BM-Homeserver da7: 40.000MB/s transfers
Mar 7 17:37:51 BM-Homeserver da7: 7630853MB (15627986944 512 byte sectors)
Mar 7 17:37:51 BM-Homeserver da7: quirks=0x2<NO_6_BYTE>
root@BM-Homeserver[~]# usbconfig
ugen1.1: <Intel EHCI root HUB> at usbus1, cfg=0 md=HOST spd=HIGH (480Mbps) pwr=S AVE (0mA)
ugen0.1: <Intel EHCI root HUB> at usbus0, cfg=0 md=HOST spd=HIGH (480Mbps) pwr=S AVE (0mA)
ugen1.2: <vendor 0x8087 product 0x8000> at usbus1, cfg=0 md=HOST spd=HIGH (480Mb ps) pwr=SAVE (0mA)
ugen0.2: <vendor 0x8087 product 0x8008> at usbus0, cfg=0 md=HOST spd=HIGH (480Mb ps) pwr=SAVE (0mA)
ugen1.3: <vendor 0x0557 product 0x7000> at usbus1, cfg=0 md=HOST spd=HIGH (480Mb ps) pwr=SAVE (100mA)
ugen1.4: <vendor 0x0557 product 0x2419> at usbus1, cfg=0 md=HOST spd=LOW (1.5Mbp s) pwr=ON (160mA)
ugen1.5: <Generic 4-Port USB 2.0 Hub> at usbus1, cfg=0 md=HOST spd=HIGH (480Mbps ) pwr=SAVE (0mA)
ugen1.6: <Western Digital Elements 25A3> at usbus1, cfg=0 md=HOST spd=HIGH (480M bps) pwr=ON (30mA)
ugen1.7: <Western Digital Elements 25A3> at usbus1, cfg=0 md=HOST spd=HIGH (480M bps) pwr=ON (30mA)
ugen1.8: <Western Digital Elements 25A3> at usbus1, cfg=0 md=HOST spd=HIGH (480M bps) pwr=ON (30mA)
ugen1.9: <Western Digital Elements 25A3> at usbus1, cfg=0 md=HOST spd=HIGH (480M bps) pwr=ON (30mA)
<ATA Patriot Burst 61.3> at scbus0 target 1 lun 0 (pass0,da0)
<ATA Patriot Burst 61.3> at scbus0 target 2 lun 0 (pass1,da1)
<ATA Patriot Burst J1.3> at scbus0 target 3 lun 0 (pass2,da2)
<ATA Patriot Burst KA.3> at scbus0 target 4 lun 0 (pass3,da3)
<Intenso SSD Q1107A0> at scbus1 target 0 lun 0 (pass4,ada0)
<Intenso SSD Q1013E1> at scbus2 target 0 lun 0 (pass5,ada1)
<WDC WD80EMAZ-00WJTA0 83.H0A83> at scbus3 target 0 lun 0 (pass6,ada2)
<WDC WD80EMAZ-00WJTA0 83.H0A83> at scbus4 target 0 lun 0 (pass7,ada3)
<WDC WD80EMAZ-00WJTA0 83.H0A83> at scbus5 target 0 lun 0 (pass8,ada4)
<WDC WD80EMAZ-00WJTA0 83.H0A83> at scbus6 target 0 lun 0 (pass9,ada5)
<AHCI SGPIO Enclosure 2.00 0001> at scbus7 target 0 lun 0 (pass10,ses0)
<WD Elements 25A3 1021> at scbus9 target 0 lun 0 (da4,pass11)
<WD Elements 25A3 1021> at scbus10 target 0 lun 0 (da5,pass12)
<WD Elements 25A3 1021> at scbus11 target 0 lun 0 (da6,pass13)
<WD Elements 25A3 1021> at scbus12 target 0 lun 0 (da7,pass14)
