hi everyone,
I need help with my brand new truenas 13 core système.
I had to change my old computer with a new one and I installed truenas 13 core that have a full device support. The only thing I kept was my ICYBOX that is a 4 sata hard drives dock, connecting in USB 3.0 to the truenas server.
So my problem is that not all my drives appear on storage/disks (the same in create pool tab). I only have one of my 3 disks that appear mounted as "da2", but when I have a look directly on the shell, I can see that all my disks were detected like "da0" "da1" and "da2".
previously my old computer used Xigmanas system with the same Icybox and all my disks appear. I changed to truenas because I had a problem with my new computer ethernet card, that is not working on xigmanas, but works good under truenas.
obviously I tried to format all the disks, so they are now completely empty, and in NTFS format, but only one is detected.
May I have help please.
Thanks a lot
Thanks a lot
