USB card not recognised
ThisTruenasUser
Hi all
I have an old machine I use as a backup.
Specs are:
CPU: i7-3770k 1Memory 16GB DDR3 Motherboard: Z77_D3H MVP
On there some drives for storage with cifs shares setup and working.
I also have a Virtual Machine (Ubuntu Linux) I use to copy from the cifs shares to external drives (ext4), attached through USB passthrough.
It does not have enough USB 3.0 ports so I got a cheap USB card on ebay.
The onboard USB ones can.
The card is not apparently working in truenas scale, so cannot use it to pass through to the virtual machine.
I did ssh into the machine and the output of lspci:
01:00.0 USB controller: VIA Technologies, Inc. VL805 USB 3.0 Host Controller (rev 01)
It is connected to the GPU pcie lane, so directly to the CPU deliberately.
How is this remedied?
it is a cheap card & not worth my time sending it back. I would prefer solution.
Thanks
Fleshmauler
From my experience it wouldn't matter if Scale doesn't have the device working if it is listed in lspci - you should be able to simply pass it through as a PCIE device by going to Virtualization, going to your VM, Devices, add, PCI Passthrough Device, putting '01:00.0' into the 2nd field. That is of course if you have VT-d enabled (and supported) in bios. Once passed through you could simply install the drivers for the device on your VM.
What does
dmesg | grep -i -e "DMAR" -e "IOMMU"
output for you?
ThisTruenasUser
From my experience it wouldn't matter if Scare doesn't have the device working if it is listed in lspci - you should be able to simply pass it through as a PCIE device by going to Virtualization, going to your VM, Devices, add, PCI Passthrough Device, putting '01:00.0' into the 2nd field. That is of course if you have VT-d enabled (and supported) in bios. Once passed through you could simply install the drivers for the device on your VM.
What does
output for you?
IOMMU is not supported on the CPU & not changing it out.
I think it is a linux driver related issue anyway. There are many posts about in in ubuntu forums.
I did not know the specific chip it uses until it was in the machine.
It was very cheap for a reason it seems.
It means I run less backups to external drives at a time, on that machine.
