StephenFry
- Apr 9, 2012
Computer hardware is not something I'm usually scared of, but I know little to nothing of electrical components and until I do, will stick to the 'better safe than sorry' approach. My question comes from me being completely ignorant and confused about currents and amps and volts and the like. Well, nearly completely, so please be gentle.
This is the issue at hand: my trusty UPS, an old(ish) APC 3000 XL beast, has a fan that, judging by its noises, is expelling its last breaths.
It never was the quietest, so ideally, replacing this fan is an opportunity to silence the unit a bit.
If my information is correct, the culprit is a 24VDC, 10W fan. It is connected to the UPS main board by only two wires. The UPS has two, and only two, settings for the fan: low and high. It is never off (even if the UPS is turned off - it needs to be "braindead", with disconnected battery, for the fan to stop).
The two settings and two wires indicate to me that there is no 'intelligent' steering (like PWN) going on and the fan speed is getting adjusted by changing the voltage...?
Does this setup allow me to replace the old fan by a lower speed / lower noise fan with *different specs*? Say, a 24VDC 5W fan? Or will the UPS likely "send" it 10W and destroy it? Don't laugh, I really have no clue.
These are some images by 5mall5nail5 I found, from the same UPS:
