UPS attached and communication established
geronimo1958
I get response with the following:
upsc ups@localhost
and I get a bunch of data like:
battery.charge: 100
battery.charge.low: 10
battery.charge.warning: 50
battery.date: not set
battery.mfr.date: 2002/10/26
battery.runtime: 4012
Including the name of my UPS (APC Back-UPS ES 725)
and when I issue the following:
upscmd -l ups
I get:
beeper.disable - Disable the UPS beeper
beeper.enable - Enable the UPS beeper
beeper.mute - Temporarily mute the UPS beeper
beeper.off - Obsolete (use beeper.disable or beeper.mute)
beeper.on - Obsolete (use beeper.enable)
load.off - Turn off the load immediately
load.off.delay - Turn off the load with a delay (seconds)
shutdown.reboot - Shut down the load briefly while rebooting the UPS
shutdown.stop - Stop a shutdown in progress
test.panel.start - Start testing the UPS panel
test.panel.stop - Stop a UPS panel test
All seems good.
But when I try and issue a command to disable the beeper:
upscmd ups beeper.disable
I get:
[myusername@freenas] # upscmd ups beeper.disable
Username (root):
Password:
Unexpected response from upsd: ERR ACCESS-DENIED
I have used all the various users and associated passwords and always get the same error. Obviously I am missing something. I have set a password in the UPS GUI section.
Any ideas?
Not all UPSes are compatible with all of those options. I've never tried to disable the beeper since I WANT to know if I'm on the battery, but that's my first guess as to what your problem is.
paleoN
You _may_ need to create an additional user with admin rights.
No _may_ about it. It's required to setup an additional user with admin rights if the OP hasn't done so already.
geronimo1958
I found some documentation on the web. I will look into adding a user with admin rights.
Thanks to all that replied.
geronimo1958
I found the location of the user file
/etc/local/nut/upsd.users
I add a user that should be able to execute some commands to the UPS.
I reboot and the changes I made disappear.
Any idea why this is happening?
geronimo1958
That just adds a single line of "user" to the upsd.users file it does not use the proper syntax
[user]
other parameters
geronimo1958
I will try and minic the syntax.
geronimo1958
That did it.
cstathoulis
Hi ,
Can someone please post "clearer" instructions on how to "upscmd ups beeper.disable" . I can't seem to find the path /etc/local/nut/upsd.users
Basically, what steps do I need to do to disable the "beeper" and what Password is required.
Username (root):
Password:
Thanks in advance.
cstathoulis
Like the thread says, it's here. To use it at FN, go to ups settings and add:
[admin]
password = mypass
instcmds = all
to EXTRA USERS field.
Have fun! ;)
Thanks for your quick reply, but silly question, I haven't been able to find where "/etc/local/nut/upsd.users" is located. Is this a default path which is created by FreeNAS or do I have to install something else.
Thanks. :)
cstathoulis
Use the GUI. Go to Services -> UPS and use EXTRA users field.
I suspected as much after going through the web and manual...
so, if I write "upscmd ups beeper.disable" in the "Services -> UPS and use EXTRA users field" I should be fine(?)
Many Thanks
SweetAndLow
Sweet'NASty
No that command needs to be run from cli.
cstathoulis
OK.... I think I have it now..(?)
From the "Services -> UPS and use EXTRA users field" we add the following:
[admin]
password = mypass (for example)
instcmds = all
and then from the FreeNAS SHELL we enter the command:
cstathoulis
It worked..!!!
Thanks a million...:D
