Upgrading from 8.2 to 9.3...issues
derek1387
So, I have been doing some research on trying to upgrade from 8.2 all the way up to 9.x, and running into problems.
I have tried through the GUI, and it just seems to get stuck and says my ISO/image or checksum is incorrect.
I downloaded a copy of my config file...what about just making a new installation on a new USB and uplading my config file...would that work?
Help please! Trying to start using Plex from FreeNAS and all the other cool plugins, but apparently 8.2 makes it difficult
I want to make sure I keep all my data on my drives as well. Running FreeNAS off of a USB stick
D
dlavigne
Guest
Yes, if the install succeeds you should be able to restore your config and import your pool.
derek1387
Looks like I was able to install 9.3 on a new jump drive....but trying to upload my config file is causing some issues. Looks like we are stuck on "re0 Link State changed to UP" for about 20 minutes....
gpsguy
Active Member
re0 is your Realtek NIC. Perhaps FreeNAS dropped support for yours along the way. I know joeschmuck ran into problems with his onboard Realtek NIC, perhaps somewhere in the 9.2.x.x versions and ended up switching to an Intel Pro/1000 CT.
I wouldn't have tried to jump all the way from 8.2 to 9.3. Perhaps 8.2 ->8.32 -> 9.2.1 -> 9.2.1.9 -> 9.3
There have been a lot of changes since 8.2
D
dlavigne
Guest
Is that during the reboot? If so, does pressing ctrl c move things along?
