Upgrading from 11.3 U5 => 12.0 has broken shares and I can't figure out how to fix them.
5hiftyy
I upgraded last Monday after doing some reading and seeing some good reviews. The upgrade went smoothly, and all the plugins seemed to be behaving properly. I attempted to access the SMB shares from my Windows 10 1903 computer per usual, but they were met with the error seen in Picture 1.
I dug around and found that my previous (terrible) habit of using root as my share accessing user was finally being forced to change. Not to worry, just create a new user. So I did, and made them owner of the requisite data sets. Still no access.
I also went through various Windows 10 settings enabling insecure guest logons etc, although that didn't seem to help any. I ended up figuring it was an upgrade bug, so I saved the config and went with a clean install + old config instead. Same issue persisted. I decided to do clean install AND brand-new setup, and that didn't change anything either. Stripping existing ACLs, making new ones, changing hostname/NetBIOS name, assigning new owner/permissions via CLI... Nothing has worked so far.
I've gotten PLEX and Tautulli running again, and they can both access the PLEX share, but I still can't login to the shares via my File Explorer or any other explorer on Windows 10 or Android. I didn't have any of these issues previously with 11.3 U5, and I WOULD roll back if not for the fact that I already updated my PLEX library pool... which was stupid of me. I'd rather not destroy 3TB of media, only because I don't want to gather it all again. The critical files are all on the pool that HAS NOT been updated yet, so I can revert still if necessary. I DO have a backup of the important data, though it's about 4wks out of date and I did a lot of reorganizing prior to this debacle so I'd rather recover this.
Debug file is attached as well.
System:
2x Xeon L5640
32GB RAM
Intel SC5520HC Motherboard
LSI IBM ServeRaid M1015 9220-8i Controller in IT Mode
ESXi 6.5
TrueNAS VM:
8x CPUs
16gb RAM
LSI Controller
20GB Boot Partition (SSD)
Drives:
4x 2TB Seagate (1 Pool; 1 Dataset; 1 SMB Share) - Personal Files
6x 1TB WD RE4 (1 Pool; 1 Dataset; 1 SMB Share) - PLEX pool
1x 100GB virtual partitioned SSD Storage (iocage, system dataset, etc) 500gb WD Blue SATA
  • debug-WATSON-20201103004932.tgz
anodos
Sambassador
  {"timestamp": "2020-10-29T21:13:54.963844-0700", "type": "Authentication", "Authentication": {"version": {"major": 1, "minor": 2}, "eventId": 4625, "logonId": "0", "logonType": 3, "status": "NT_STATUS_WRONG_PASSWORD", "localAddress": "ipv4:192.168.0.56:445", "remoteAddress": "ipv4:192.168.0.39:59174", "serviceDescription": "SMB2", "authDescription": null, "clientDomain": "MicrosoftAccount", "clientAccount": "rjenkins", "workstation": "STYX", "becameAccount": null, "becameDomain": null, "becameSid": null, "mappedAccount": "rjenkins", "mappedDomain": "MicrosoftAccount", "netlogonComputer": null, "netlogonTrustAccount": null, "netlogonNegotiateFlags": "0x00000000", "netlogonSecureChannelType": 0, "netlogonTrustAccountSid": null, "passwordType": "NTLMv2", "duration": 3334}}
  {"timestamp": "2020-10-29T21:13:56.015292-0700", "type": "Authentication", "Authentication": {"version": {"major": 1, "minor": 2}, "eventId": 4625, "logonId": "0", "logonType": 3, "status": "NT_STATUS_WRONG_PASSWORD", "localAddress": "ipv4:192.168.0.56:445", "remoteAddress": "ipv4:192.168.0.39:59176", "serviceDescription": "SMB2", "authDescription": null, "clientDomain": "MicrosoftAccount", "clientAccount": "rjenkins", "workstation": "STYX", "becameAccount": null, "becameDomain": null, "becameSid": null, "mappedAccount": "rjenkins", "mappedDomain": "MicrosoftAccount", "netlogonComputer": null, "netlogonTrustAccount": null, "netlogonNegotiateFlags": "0x00000000", "netlogonSecureChannelType": 0, "netlogonTrustAccountSid": null, "passwordType": "NTLMv2", "duration": 3339}}
  {"timestamp": "2020-10-29T21:18:58.526030-0700", "type": "Authentication", "Authentication": {"version": {"major": 1, "minor": 2}, "eventId": 4625, "logonId": "0", "logonType": 3, "status": "NT_STATUS_WRONG_PASSWORD", "localAddress": "ipv4:192.168.0.56:445", "remoteAddress": "ipv4:192.168.0.39:50536", "serviceDescription": "SMB2", "authDescription": null, "clientDomain": "MicrosoftAccount", "clientAccount": "rjenkins", "workstation": "STYX", "becameAccount": null, "becameDomain": null, "becameSid": null, "mappedAccount": "rjenkins", "mappedDomain": "MicrosoftAccount", "netlogonComputer": null, "netlogonTrustAccount": null, "netlogonNegotiateFlags": "0x00000000", "netlogonSecureChannelType": 0, "netlogonTrustAccountSid": null, "passwordType": "NTLMv2", "duration": 3322}}
  {"timestamp": "2020-10-29T21:19:05.734800-0700", "type": "Authentication", "Authentication": {"version": {"major": 1, "minor": 2}, "eventId": 4624, "logonId": "0", "logonType": 3, "status": "NT_STATUS_OK", "localAddress": "ipv4:192.168.0.56:445", "remoteAddress": "ipv4:192.168.0.39:50545", "serviceDescription": "SMB2", "authDescription": null, "clientDomain": "MicrosoftAccount", "clientAccount": "rjenkins", "workstation": "STYX", "becameAccount": "rjenkins", "becameDomain": "TRUENAS", "becameSid": "S-1-5-21-1413562809-1920715847-4041261626-1001", "mappedAccount": "rjenkins", "mappedDomain": "MicrosoftAccount", "netlogonComputer": null, "netlogonTrustAccount": null, "netlogonNegotiateFlags": "0x00000000", "netlogonSecureChannelType": 0, "netlogonTrustAccountSid": null, "passwordType": "NTLMv2", "duration": 5692}}
  {"timestamp": "2020-11-02T21:17:06.058012-0800", "type": "Authentication", "Authentication": {"version": {"major": 1, "minor": 2}, "eventId": 4625, "logonId": "0", "logonType": 3, "status": "NT_STATUS_NO_SUCH_USER", "localAddress": "ipv4:192.168.0.96:445", "remoteAddress": "ipv4:192.168.0.68:57878", "serviceDescription": "SMB2", "authDescription": null, "clientDomain": "MicrosoftAccount", "clientAccount": "root", "workstation": "STYX", "becameAccount": null, "becameDomain": null, "becameSid": null, "mappedAccount": "root", "mappedDomain": "MicrosoftAccount", "netlogonComputer": null, "netlogonTrustAccount": null, "netlogonNegotiateFlags": "0x00000000", "netlogonSecureChannelType": 0, "netlogonTrustAccountSid": null, "passwordType": "NTLMv2", "duration": 3410}}
  {"timestamp": "2020-11-02T21:27:48.374329-0800", "type": "Authentication", "Authentication": {"version": {"major": 1, "minor": 2}, "eventId": 4625, "logonId": "0", "logonType": 3, "status": "NT_STATUS_NO_SUCH_USER", "localAddress": "ipv4:192.168.0.96:445", "remoteAddress": "ipv4:192.168.0.68:58304", "serviceDescription": "SMB2", "authDescription": null, "clientDomain": "MicrosoftAccount", "clientAccount": "russell.jenkins017@live.com", "workstation": "STYX", "becameAccount": null, "becameDomain": null, "becameSid": null, "mappedAccount": "russell.jenkins017@live.com", "mappedDomain": "MicrosoftAccount", "netlogonComputer": null, "netlogonTrustAccount": null, "netlogonNegotiateFlags": "0x00000000", "netlogonSecureChannelType": 0, "netlogonTrustAccountSid": null, "passwordType": "NTLMv2", "duration": 7042}}
  {"timestamp": "2020-11-02T21:30:35.852130-0800", "type": "Authentication", "Authentication": {"version": {"major": 1, "minor": 2}, "eventId": 4625, "logonId": "0", "logonType": 3, "status": "NT_STATUS_NO_SUCH_USER", "localAddress": "ipv4:192.168.0.96:445", "remoteAddress": "ipv4:192.168.0.68:58392", "serviceDescription": "SMB2", "authDescription": null, "clientDomain": "MicrosoftAccount", "clientAccount": "russell.jenkins017@live.com", "workstation": "STYX", "becameAccount": null, "becameDomain": null, "becameSid": null, "mappedAccount": "russell.jenkins017@live.com", "mappedDomain": "MicrosoftAccount", "netlogonComputer": null, "netlogonTrustAccount": null, "netlogonNegotiateFlags": "0x00000000", "netlogonSecureChannelType": 0, "netlogonTrustAccountSid": null, "passwordType": "NTLMv2", "duration": 2753}}
Client from 192.168.0.39 struggles getting the right password (eventually succeeding). 192.168.0.68 keeps sending the wrong username.
5hiftyy
That may have been me with 1am brain trying all sorts of combinations of passwords or usernames. I had reset the password for user rjenkins prior to a restart, and Was grasping at straws with the whole mapping thing.
This is the debug after successfully connecting and mapping the network drive this morning. I now have it successfully mapped, but it is still throwing the same error as before. I'm looking at the auth_audit.log and can't find anything that says TrueNAS is rejecting the login?
  • debug-WATSON-20201103101440.tgz
anodos
Sambassador
[2020/11/03 07:15:10.046243,  0] ../../source3/smbd/service.c:183(chdir_current_service)
  chdir_current_service: vfs_ChDir(/mnt/KNOX/RJ) failed: Permission denied. Current token: uid=1000, gid=1000, 5 groups: 1000 545 90000001 90000002 90000004
Now the password isn't being rejected, but your user doesn't have permissions.
Mountpoint ACL:
# file: /mnt/KNOX
# owner: root
# group: wheel
            owner@:rwxp--aARWcCos:-------:allow
            group@:rwxp--a-R-c--s:-------:allow
         everyone@:------a-R-c--s:-------:allow
Specifically, it looks like we've had a "chmod 770" on /mnt/KNOX. Your feet are cut out from under yourself. Run following command: chmod 755 /mnt/KNOX
5hiftyy
That solved it. You're a legend. Worked on both shares I couldn't access before. I had tried to use the chmod 777/775 commands previously, I guess this is my inexperience showing.
Thank you SO much for your help!
5hiftyy
Mountpoint ACL:
# file: /mnt/KNOX
# owner: root
# group: wheel
Would you also mind letting me know which log file you looked at to find the info? I'd like to be able to check this in the future if I ever run into this again. Thank you again!!
