How would one go about to upgrade from the release version of freenas 8 to the beta 4? It says something in the notes that you can't upgrade from previous versions than beta 3. Is the way to do this to upgrade first to beta 3 and then to beta 4?
Read the Release Notes a bit closer. You can upgrade from earlier 8 versions, but only from CD (i.e. not from the GUI). The other option is to save the config, reinstall the new version, then restore the config. A fuller description is at http://doc.freenas.org/index.php/Upgrading_FreeNAS.
I was just very conscious of losing my data and didn't dare do anything before I heard from an actual person. Thank you for your reply, I will read it thourugly. :)
Most importantly, if your install device is smaller than 2GB, you can't upgrade directly to 8.01 Beta 3 or later, and will need to take an indirect upgrade path.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
