HavaCuppaJoe
- Jul 4, 2011
I have 8.0.1 beta 2 up and running with a 4x2TB RAIDZ array booting from a 2GB flash drive. Anyhow, I've been testing it with sample/scratch data for a week or so now. Have run into a few of the known issues with beta 2, so am trying to upgrade to beta 3.
However, the upgrade won't boot completely. It always bombs out with a mounting error before executing the config menu (or configuring the network controller, for that matter). I've tried both installing to a new USB flash drive and updating the existing flash drive from CD (ISO image) and run into the same results. On the ISO install, the disk image finds the Beta2 key, reports that it's saved the config file, re-images the flash drive, reports that it updated the config file on the new image successfully; then promptly fails on the next reboot.
Was hoping that someone has seen this before and can help this Noob get around whatever this configuration issue is.
When the error occurs, the last few lines on the console are always this:
At this point it looks like the drive is in read-only mode or something, because I can't even look at the log files with view; it reports that that it can't create a temp file on the media.
Does this look like some variation of the permissions error that I read about on the other threads? Any advice would be appreciated.
My config (high level) is:
ASUS mobo - M5A78L-M LX
Athlon X2 255
4x 2TB Seagate Green drives
4GB RAM
Booting FreeNAS from USB flash drive
Thanks,
HavaCuppaJoe
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs1a
mount: /dev/ufs/FreeNASs3 : No such file or directory
mount -o ro /dev/ufs/FreeNASs3 /conf/default/etc failed: dropping into /bin/sh
Athlon X2 255
4GB RAM
Thanks,
HavaCuppaJoe
