upgraded from 11.3U5 to 12 - jails read only
gwaitsi
I upgraded from freenas 11.3U5 to Truenas and upgraded the jails.
I note that all the jails are read only, even when down and edit is used.
i deleted my old zoneminder, and re-created a new one but it too is read only, so i can't change any settings that i need to.
** i might add, if you go to install the plugin and then click on advanced installation, everything is already read only.
running jails are always read-only... have you tried editing the jail when it's stopped?
gwaitsi
maybe i wasn't clear enough.
1) it is read only during the plugin installation process when switching to the advanced install - everything becomes read only
2) when stopping a jail and attempting to edit, everything is read only.
In both use cases, it previously allowed editing under 11.3U5
I'm clear on the problem but can't suggest much as it's working as expected on all of my TrueNAS 12.0 Core systems.
