I decided to take the plunge and install the upgrade file.
After file extraction, which took some time, it rebooted at some point as I had to do something else and could not sit and watch. About 30 minutes later I came back and saw a screen full of text scrolling up and telling me nothing which I could tell anyone here.
Apart from what I copied off my web address page
Request Method: GET
Request URL: http://192.168.0.28/account/login/?next=/
Software Version: FreeNAS-9.3-STABLE-201412090314
Exception Type: OperationalError
Exception Value:
no such column: system_settings.stg_guicertificate_id
Exception Location: /usr/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py in execute, line 452
Server time: Sat, 13 Dec 2014 12:52:41 +0000
And then this which was in a scroll box
Environment:
Request Method: GET
Traceback:
File "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in get_response
88. response = middleware_method(request)
File "/usr/local/www/freenasUI/../freenasUI/freeadmin/middleware.py" in process_request
181. language = Settings.objects.order_by('-id')[0].stg_language
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py" in __getitem__
132. return list(qs)[0]
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py" in __iter__
96. self._fetch_all()
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py" in _fetch_all
857. self._result_cache = list(self.iterator())
File "/usr/local/lib/python2.7/site-packages/django/db/models/query.py" in iterator
220. for row in compiler.results_iter():
File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py" in results_iter
713. for rows in self.execute_sql(MULTI):
File "/usr/local/lib/python2.7/site-packages/django/db/models/sql/compiler.py" in execute_sql
786. cursor.execute(sql, params)
File "/usr/local/lib/python2.7/site-packages/django/db/backends/util.py" in execute
53. return self.cursor.execute(sql, params)
File "/usr/local/lib/python2.7/site-packages/django/db/utils.py" in __exit__
99. six.reraise(dj_exc_type, dj_exc_value, traceback)
File "/usr/local/lib/python2.7/site-packages/django/db/backends/sqlite3/base.py" in execute
452. return Database.Cursor.execute(self, query, params)
Exception Type: OperationalError at /account/login/
Exception Value: no such column: system_settings.stg_guicertificate_id
Can anyone shed any light on what caused and why it failed
Request Method: GET
Exception Value:
Environment:
Request Method: GET
Traceback:
