Daisuke
 - Jun 23, 2011
Hi all,
I'm running latest 8.3 release and I plan to install 9.1.0 soon but as clean install. There is a little puzzle posted on Wiki:
It should show me a list of pools I want to import. Thanks.
I never had to re-import my disks before, what is the proper procedure? I'm used to deal with terminal commands, is it simply this?NOTE: if you select to perform a Fresh Install, you will have to re-import your disks and restore the backup of your configuration.
# zpool import
