Upgrade from 8.3.1 to 9.1.0 as fresh install
Daisuke
Hi all,
I'm running latest 8.3 release and I plan to install 9.1.0 soon but as clean install. There is a little puzzle posted on Wiki:
NOTE: if you select to perform a Fresh Install, you will have to re-import your disks and restore the backup of your configuration.
I never had to re-import my disks before, what is the proper procedure? I'm used to deal with terminal commands, is it simply this?
# zpool import
It should show me a list of pools I want to import. Thanks.
Importing your zpool is thoroughly explained in the manual.
Ismael Duarte
I don't know if I've made it right, but after restore configuration everything is working, includind hard disks. Should I do something more?
Nope. If you are importing a configuration the zpool doesn't have to be imported.
