Upgrade from 8.0.4 to 8.2.0.p1 problem
wojtek
Web upgrade form 8.0.4 to 8.2.0.p1 took long time - about 1h and didn't end. In /var/log/messages I have:
Aug  8 08:40:06 nas2 freenas[1902]: Executing: /bin/rm -rf /var/tmp/firmware
Aug  8 08:40:06 nas2 freenas[1902]: Executing: /bin/mkdir -p /mnt/backup/.freenas
Aug  8 08:40:06 nas2 freenas[1902]: Executing: /usr/sbin/chown www:www /mnt/backup/.freenas
Aug  8 08:40:06 nas2 freenas[1902]: Executing: /bin/ln -s /mnt/backup/.freenas /var/tmp/firmware
Aug  8 08:42:48 nas2 freenas[1902]: Executing: /bin/rm -rf /var/tmp/firmware
Aug  8 08:42:48 nas2 freenas[1902]: Executing: /bin/mkdir -p /mnt/backup/.freenas
Aug  8 08:42:48 nas2 freenas[1902]: Executing: /usr/sbin/chown www:www /mnt/backup/.freenas
Aug  8 08:42:48 nas2 freenas[1902]: Executing: /bin/ln -s /mnt/backup/.freenas /var/tmp/firmware
Aug  8 08:42:48 nas2 freenas[1902]: Popen()ing: /sbin/sha256 -q /var/tmp/firmware/firmware.xz
Aug  8 08:42:50 nas2 freenas[1902]: Executing: /usr/bin/xz -t /var/tmp/firmware/firmware.xz
Aug  8 08:43:07 nas2 freenas[1902]: Executing: /usr/bin/xz -cd /var/tmp/firmware/firmware.xz | sh /root/update && touch /data/need-update
Aug  8 08:45:37 nas2 freenas: 1930257+0 records in
Aug  8 08:45:37 nas2 freenas: 7540+1 records out
Aug  8 08:45:37 nas2 freenas: 988291584 bytes transferred in 149.259309 secs (6621306 bytes/sec)
Aug  8 08:45:37 nas2 kernel: GEOM: da0s2: geometry does not match label (16h,63s != 255h,63s).
Aug  8 08:45:43 nas2 freenas: ** /dev/da0s2a (NO WRITE)
Aug  8 08:45:43 nas2 freenas: ** Last Mounted on /build/home/jpaetzel/8.2.0/os-base/amd64/_.mnt
Aug  8 08:45:43 nas2 freenas: ** Phase 1 - Check Blocks and Sizes
Aug  8 08:45:43 nas2 freenas: ** Phase 2 - Check Pathnames
Aug  8 08:45:43 nas2 freenas: ** Phase 3 - Check Connectivity
Aug  8 08:45:43 nas2 freenas: ** Phase 4 - Check Reference Counts
Aug  8 08:45:43 nas2 freenas: ** Phase 5 - Check Cyl groups
Aug  8 08:45:43 nas2 freenas: 22994 files, 723648 used, 1174158 free (694 frags, 146683 blocks, 0.0% fragmentation)
Aug  8 08:45:43 nas2 freenas: tar: Removing leading '/' from member names
Aug  8 08:45:43 nas2 freenas: x boot/modules/
Aug  8 08:45:43 nas2 freenas: active set on da0s2
Aug  8 08:45:43 nas2 freenas[1902]: Executing: /bin/rm -fr /var/tmp/firmware/firmware.xz
Aug  8 08:47:09 nas2 freenas[1902]: Executing: /bin/rm -rf /var/tmp/firmware
Aug  8 08:47:09 nas2 freenas[1902]: Executing: /bin/mkdir -p /mnt/backup/.freenas
Aug  8 08:47:09 nas2 freenas[1902]: Executing: /usr/sbin/chown www:www /mnt/backup/.freenas
Aug  8 08:47:09 nas2 freenas[1902]: Executing: /bin/ln -s /mnt/backup/.freenas /var/tmp/firmware
Aug  8 08:47:09 nas2 freenas[1902]: Popen()ing: /sbin/sha256 -q /var/tmp/firmware/firmware.xz
Aug  8 08:47:11 nas2 freenas[1902]: Executing: /usr/bin/xz -t /var/tmp/firmware/firmware.xz
Aug  8 08:47:27 nas2 freenas[1902]: Executing: /usr/bin/xz -cd /var/tmp/firmware/firmware.xz | sh /root/update && touch /data/need-update
Aug  8 08:49:57 nas2 freenas: 1930257+0 records in
Aug  8 08:49:57 nas2 freenas: 7540+1 records out
Aug  8 08:49:57 nas2 freenas: 988291584 bytes transferred in 150.108029 secs (6583869 bytes/sec)
Aug  8 08:49:58 nas2 kernel: GEOM: da0s2: geometry does not match label (16h,63s != 255h,63s).
Aug  8 08:50:03 nas2 freenas: ** /dev/da0s2a (NO WRITE)
Aug  8 08:50:03 nas2 freenas: ** Last Mounted on /build/home/jpaetzel/8.2.0/os-base/amd64/_.mnt
Aug  8 08:50:03 nas2 freenas: ** Phase 1 - Check Blocks and Sizes
Aug  8 08:50:03 nas2 freenas: ** Phase 2 - Check Pathnames
Aug  8 08:50:03 nas2 freenas: ** Phase 3 - Check Connectivity
Aug  8 08:50:03 nas2 freenas: ** Phase 4 - Check Reference Counts
Aug  8 08:50:03 nas2 freenas: ** Phase 5 - Check Cyl groups
Aug  8 08:50:03 nas2 freenas: 22994 files, 723648 used, 1174158 free (694 frags, 146683 blocks, 0.0% fragmentation)
Aug  8 08:50:03 nas2 freenas: tar: Removing leading '/' from member names
Aug  8 08:50:04 nas2 freenas: x boot/modules/
Aug  8 08:50:04 nas2 freenas: active set on da0s2
Aug  8 08:50:04 nas2 freenas[1902]: Executing: /bin/rm -fr /var/tmp/firmware/firmware.xz
Aug  8 08:51:30 nas2 freenas[1902]: Executing: /bin/rm -rf /var/tmp/firmware
Aug  8 08:51:30 nas2 freenas[1902]: Executing: /bin/mkdir -p /mnt/backup/.freenas
Aug  8 08:51:30 nas2 freenas[1902]: Executing: /usr/sbin/chown www:www /mnt/backup/.freenas
Aug  8 08:51:30 nas2 freenas[1902]: Executing: /bin/ln -s /mnt/backup/.freenas /var/tmp/firmware
Aug  8 08:51:30 nas2 freenas[1902]: Popen()ing: /sbin/sha256 -q /var/tmp/firmware/firmware.xz
Aug  8 08:51:32 nas2 freenas[1902]: Executing: /usr/bin/xz -t /var/tmp/firmware/firmware.xz
Aug  8 08:51:48 nas2 freenas[1902]: Executing: /usr/bin/xz -cd /var/tmp/firmware/firmware.xz | sh /root/update && touch /data/need-update
Aug  8 08:54:17 nas2 freenas: 1930257+0 records in
Aug  8 08:54:17 nas2 freenas: 7540+1 records out
Aug  8 08:54:17 nas2 freenas: 988291584 bytes transferred in 148.674096 secs (6647369 bytes/sec)
Aug  8 08:54:17 nas2 kernel: GEOM: da0s2: geometry does not match label (16h,63s != 255h,63s).
Aug  8 08:54:23 nas2 freenas: ** /dev/da0s2a (NO WRITE)
Aug  8 08:54:23 nas2 freenas: ** Last Mounted on /build/home/jpaetzel/8.2.0/os-base/amd64/_.mnt
Aug  8 08:54:23 nas2 freenas: ** Phase 1 - Check Blocks and Sizes
Aug  8 08:54:23 nas2 freenas: ** Phase 2 - Check Pathnames
Aug  8 08:54:23 nas2 freenas: ** Phase 3 - Check Connectivity
Aug  8 08:54:23 nas2 freenas: ** Phase 4 - Check Reference Counts
Aug  8 08:54:23 nas2 freenas: ** Phase 5 - Check Cyl groups
Aug  8 08:54:23 nas2 freenas: 22994 files, 723648 used, 1174158 free (694 frags, 146683 blocks, 0.0% fragmentation)
Aug  8 08:54:23 nas2 freenas: tar: Removing leading '/' from member names
Aug  8 08:54:23 nas2 freenas: x boot/modules/
Aug  8 08:54:24 nas2 freenas: active set on da0s2
Can anybody help ?
I'd get a new USB key, install FreeNAS 8.2, then restore your config file.
wojtek
I have two freenas servers, both in 8.0.4 version. I start upgrade to 8.2.0 with secondary server. This is official procedure ?
Yep. Manual provides the steps to backup and restore your config file.
