FarmerFred
- May 14, 2013
I'm a freenas noob so go easy on me... :)
I just setup 9.1 from scratch and I'm seeing items on the console which I don't understand (I was playing around with 8.3.1 before in the same setup without seeing all these warnings/errors)
My setup is pretty simple, the freenas box is joined to the activate directory domain and I have a couple shares. When I access the shares I noticed a new item: "Matchname failed" where I didn't see that on the console of 8.3.1 and only for my machine, not another test machine i'm using.
There's also two items that appear over and over
Aug 8 14:24:07 rdisfreenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v
Aug 8 14:24:07 rdisfreenas last message repeated 2 times
and the few lines around dump_workgroups()
Can anyone tell me if there's a problem or what all this entries are about? I was running 8.3.1 for a few weeks and the console had nothing and with 9.1 I've got tons of stuff within minutes.
Aug 8 14:14:54 rdisfreenas root: /etc/rc: WARNING: Dump device does not exist. Savecore not run.
Aug 8 14:15:09 rdisfreenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Aug 8 14:15:10 rdisfreenas kernel: .
Aug 8 14:15:10 rdisfreenas ntpd[2723]: ntpd 4.2.4p5-a (1)
Aug 8 14:15:36 rdisfreenas avahi-daemon[3822]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Aug 8 14:15:52 rdisfreenas winbindd[4287]: [2013/08/08 14:15:52.998182, 0] winbindd/idmap_tdb.c:149(idmap_tdb_upgrade)
Aug 8 14:15:52 rdisfreenas winbindd[4287]: Upgrading winbindd_idmap.tdb from an old version
Aug 8 14:16:30 rdisfreenas smbd[3665]: [2013/08/08 14:16:30.217877, 0] lib/util_sock.c:1264(get_peer_name)
Aug 8 14:16:30 rdisfreenas smbd[3665]: Matchname failed on mymachine.mydomain.com 10.0.30.116
Aug 8 14:21:02 rdisfreenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v
Aug 8 14:21:03 rdisfreenas last message repeated 2 times
Aug 8 14:22:40 rdisfreenas manage.py: [py.warnings:744] /usr/local/www/freenasUI/../freenasUI/common/freenasldap.py:744: DeprecationWarning: object() takes no parameters obj = super(FreeNAS_ActiveDirectory_Base, cls).__new__(cls, **kwargs)
Aug 8 14:22:59 rdisfreenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v
Aug 8 14:22:59 rdisfreenas last message repeated 2 times
Aug 8 14:23:49 rdisfreenas notifier: Performing sanity check on Samba configuration: OK
Aug 8 14:23:49 rdisfreenas notifier: Reloading nmbd.
Aug 8 14:23:50 rdisfreenas notifier: Reloading smbd.
Aug 8 14:23:50 rdisfreenas notifier: Reloading winbindd.
Aug 8 14:23:51 rdisfreenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list -v
Aug 8 14:23:51 rdisfreenas last message repeated 2 times
Aug 8 14:24:06 rdisfreenas notifier: Performing sanity check on Samba configuration: OK
Aug 8 14:24:06 rdisfreenas notifier: Reloading nmbd.
Aug 8 14:24:06 rdisfreenas nmbd[3662]: [2013/08/08 14:24:06.166325, 0] nmbd/nmbd_workgroupdb.c:276(dump_workgroups)
Aug 8 14:24:06 rdisfreenas nmbd[3662]: dump_workgroups()
Aug 8 14:24:06 rdisfreenas nmbd[3662]: dump workgroup on subnet 10.2.4.106: netmask= 255.255.0.0:
Aug 8 14:24:06 rdisfreenas nmbd[3662]: DOMAIN(1) current master browser = IT-LOANER-E64Z
Aug 8 14:24:06 rdisfreenas nmbd[3662]: RDISFREENAS 40809b23 (FreeNAS Server)
Aug 8 14:24:06 rdisfreenas nmbd[3662]: PE1850D 40849007 ()
Aug 8 14:24:06 rdisfreenas nmbd[3662]: IT-LOANER-E64Z 40051007 ()
Aug 8 14:24:06 rdisfreenas nmbd[3662]: [2013/08/08 14:24:06.167038, 0] nmbd/nmbd_workgroupdb.c:276(dump_workgroups)
Aug 8 14:24:06 rdisfreenas nmbd[3662]: dump workgroup on subnet UNICAST_SUBNET: netmask= 0.0.0.0:
Aug 8 14:24:06 rdisfreenas nmbd[3662]: DOMAIN(1) current master browser = UNKNOWN
Aug 8 14:24:06 rdisfreenas notifier: Reloading smbd.
Aug 8 14:24:06 rdisfreenas notifier: Reloading winbindd.
