Well, I thought I found an option under System->Boot->Status->Replace that would just copy the actual boot pool to a new one.
I tried this, replacing my USB Dongle pool with the empty SSD, and using the `zpool status` command I could see that it was resilvering the new SSD.
I had a doubt that TrueNAS would be able to restart from this new boot pool with just this, and in effect it didn't restart with the SSD as the first boot option in BIOS.
I then reinstalled from scratch on the SSD, trying Upgrade install, but still couldn't boot from the device.
Did a Fresh install. Still can't boot from it.
It now sounds like a pretty bad sequence of things.
It's hard to believe there's anything wrong with the SSD.
I tried to change the SATA channel, but anyway the SSD is listed in the BIOS boot option, I don't think it could be this.
Then again I tried Upgrade install and Format the boot device, still to no avail.
To top it all I'm now facing also an uncorrectable I/O failure on the USB boot-pool.
Any idea on how a BIOS listed device could be not bootable after a successful installation ?
