Issue upgrading from 12.0-U5.1 to 12.0-U6
pfonseca
I've a functional v12.0-U5.1 system. When I've tried to upgrade it to v12.0-U6 through GUI interface, it seems that everything works OK, but, finally the system doesn't come up, without network connectivity.
I've installed v12.0-U6 from iso image in a a new boot environment the system comes up with a DHCP IP configured automatically and I was able to apply the config file freenas-v1.db, obtained before de GUI upgrade. After that I reboot the system and it doesn't come up.
I've done a fresh installation again, go system/boot choose v12.0-U5.1 boot environment again and everything is working fine.
Because I have the system hanging the console on boot (after an upgrade to I don't remember whatever v11.x it was, I was never able to recover from that, whatever I tried to change on BIOS) , as the picture included, I can't verify what's happening .
Any clue about what's happening?
Regards,
Patrick M. Hausen
What are you using as a boot drive?
Spearfoot
He of the long foot
Regards,
Please post full information about your system per the forum rules (linked in red above). This will give us a better chance of helping with your problem.
pfonseca
As already said, I've functional TrueNAS Core v12-U5.1 based on system with:
- This board https://www.asus.com/us/Motherboards-Components/Motherboards/Business/N3150IC/ with 8GB RAM and a SATA 4-Port PCIe board;
- it is configured with two RAD1 pools for data, with 4 disks attached to PCIe board and a SATA disk dedicated, attache to the controller on-board, for boot;
I use this system as a NAS to store and share files at home and two jails, PLEX for media share and a syslog server to consolidate logs from several devices at home.
I attach two files result of lspci -v and cat /var/run/dmesg.boot
I hope this helps.
Regards,
  • dmesg.boot.txt
  • pcilist.txt
Spearfoot
He of the long foot
pfonseca
If you're using a SATA PCIe board, that might be the source of your problems; sometimes FreeBSD (TrueNAS/FreeNAS) dooesn't support these very well.
What brand and model of SATA PCIe board are you using?
I've this board since v9 whatever.
I don't remember the brand of the board, but believing in dmesg description, it has a chipset like this "Marvell 88SE9235 AHCI SATA controller".
Regards,
