Upgrade failure from 8.0.3 to 8.3.0
DaJe
I tried to upgrade my FreeNAS from 8.0.3 to 8.3.0 and did get a database upgrade failure.
Hopefully, the system rebooted on my original 8.0.3.
Here is the /data/update.failed file:
View attachment update.failed.txt
What is the important information in this file? Is it the last line? If yes, how should I interpret it? Does it mean there is a missing column in my FreeNAS db?
Thanks for your help.
Damien.
Honestly, it looks like the important information is that you are pretty much stuck with 8.0.3 unless you are willing to rebuild your config file from scratch. Note that your data on ZFS/UFS will still be safe.
Honestly, you should seriously consider putting in the time to upgrade to 8.3.0. There are security issues with older versions as well as a boatload of bug fixes.
paleoN
One other thing you can try. See this [post=36212]post by survive[/post].
