When I try to update to U3.1 I get the following error.
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/update.py", line 663, in do_update
if ApplyUpdate(dest_extracted) is None:
File "/usr/local/lib/freenasOS/Update.py", line 1627, in ApplyUpdate
raise e
File "/usr/local/lib/freenasOS/Update.py", line 1559, in ApplyUpdate
if installer.InstallPackages(progressFunc=progressFunc, handler=install_handler) is False:
File "/usr/local/lib/freenasOS/Installer.py", line 1088, in InstallPackages
trampoline=self.trampoline) is False:
File "/usr/local/lib/freenasOS/Installer.py", line 823, in install_file
if pkgdb.RemovePackageFiles(pkgName) == False:
File "/usr/local/lib/freenasOS/Configuration.py", line 347, in RemovePackageFiles
raise Exception("Cannot remove file %s" % path)
Exception: Cannot remove file /root/.bashrc
File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 349, in run
await self.future
File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 386, in __run_body
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 961, in nf
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/update.py", line 668, in file
await self.middleware.run_in_thread(do_update)
File "/usr/local/lib/python3.7/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.7/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/update.py", line 666, in do_update
raise CallError(str(e))
middlewared.service_exception.CallError: [EFAULT] Cannot remove file /root/.bashrc
Not sure how to to get past this.
Thanks
raise e
await self.future
Thanks
