SOLVED 12.0-U1 Update: [Errno 13] Permission denied
vzbptbcs
I just wanted to upgrade my system from 12.0 to 12.0-U1 via the webinterface, but I get this error message:
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 361, in run
    await self.future
  File "/usr/local/lib/python3.8/site-packages/middlewared/job.py", line 399, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *([self] + args))
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
    return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
  File "/usr/local/lib/python3.8/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 977, in nf
    return f(*args, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/update.py", line 315, in download
    return self.middleware.call_sync('update.download_update', job, train, location, 100)
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1249, in call_sync
    return self.run_coroutine(methodobj(*prepared_call.args))
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1289, in run_coroutine
    return fut.result()
  File "/usr/local/lib/python3.8/concurrent/futures/_base.py", line 432, in result
    return self.__get_result()
  File "/usr/local/lib/python3.8/concurrent/futures/_base.py", line 388, in __get_result
    raise self._exception
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/update.py", line 319, in download_update
    success = await self.middleware.call('update.download_impl', *args)
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1233, in call
    return await self._call(
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1202, in _call
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1106, in run_in_executor
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/update_/download_freebsd.py", line 16, in download_impl
    Update.DownloadUpdate(
  File "/usr/local/lib/freenasOS/Update.py", line 1074, in DownloadUpdate
    latest_mani.RunValidationProgram(directory, kind=Manifest.VALIDATE_UPDATE)
  File "/usr/local/lib/freenasOS/Manifest.py", line 682, in RunValidationProgram
    subprocess.check_output(valid_script, preexec_fn=PreExecHook, stderr=subprocess.STDOUT)
  File "/usr/local/lib/python3.8/subprocess.py", line 411, in check_output
    return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
  File "/usr/local/lib/python3.8/subprocess.py", line 489, in run
    with Popen(*popenargs, **kwargs) as process:
  File "/usr/local/lib/python3.8/subprocess.py", line 854, in __init__
    self._execute_child(args, executable, preexec_fn, close_fds,
  File "/usr/local/lib/python3.8/subprocess.py", line 1702, in _execute_child
    raise child_exception_type(errno_num, err_msg, err_filename)
PermissionError: [Errno 13] Permission denied: './ValidateUpdate'
I am not sure what I should do now?
Alecmascot
A search of the forum would have found the solution.
You have no-exec set.
"zfs set exec=on tank/.system" should fix it while keeping no-exec on the rest of the pool.
