gyp ERR! build error
gyp ERR! stack Error: gmake failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/pbi/mineos-amd64/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
gyp ERR! stack at ChildProcess.emit (events.js:98:17)
gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:810:12)
gyp ERR! System FreeBSD 11.1-STABLE
gyp ERR! command “node” “/usr/pbi/mineos-amd64/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
gyp ERR! cwd /usr/pbi/mineos-amd64/share/mineos/mineos-node/node_modules/posix
gyp ERR! node -v v0.10.31
gyp ERR! node-gyp -v v1.0.1
gyp ERR! not ok
npm WARN engine request@2.79.0: wanted: {“node”:">= 4"} (current: {“node”:“0.10.31”,“npm”:“1.4.25”})
npm WARN engine esprima@4.0.0: wanted: {“node”:">=4"} (current: {“node”:“0.10.31”,“npm”:“1.4.25”})
npm WARN engine hawk@3.1.3: wanted: {“node”:">=0.10.32"} (current: {“node”:“0.10.31”,“npm”:“1.4.25”})
npm WARN engine form-data@2.1.4: wanted: {“node”:">= 0.12"} (current: {“node”:“0.10.31”,“npm”:“1.4.25”})
npm WARN engine cryptiles@2.0.5: wanted: {“node”:">=0.10.40"} (current: {“node”:“0.10.31”,“npm”:“1.4.25”})
npm WARN engine boom@2.10.1: wanted: {“node”:">=0.10.40"} (current: {“node”:“0.10.31”,“npm”:“1.4.25”})
npm WARN engine hoek@2.16.3: wanted: {“node”:">=0.10.40"} (current: {“node”:“0.10.31”,“npm”:“1.4.25”})
moment@2.21.0 usr/pbi/mineos-amd64/share/mineos/mineos-node/node_modules/moment
request@2.74.0 usr/pbi/mineos-amd64/share/mineos/mineos-node/node_modules/request
├── is-typedarray@1.0.0
├── oauth-sign@0.8.2
├── aws-sign2@0.6.0
├── forever-agent@0.6.1
├── stringstream@0.0.6
├── tunnel-agent@0.4.3
├── caseless@0.11.0
├── isstream@0.1.2
├── json-stringify-safe@5.0.1
├── aws4@1.7.0
├── extend@3.0.1
├── combined-stream@1.0.6 (delayed-stream@1.0.0)
├── qs@6.2.3
├── mime-types@2.1.18 (mime-db@1.33.0)
├── tough-cookie@2.3.4 (punycode@1.4.1)
├── bl@1.1.2 (readable-stream@2.0.6)
├── har-validator@2.0.6 (commander@2.15.1, pinkie-promise@2.0.1, chalk@1.1.3, is-my-json-valid@2.17.2)
├── hawk@3.1.3 (cryptiles@2.0.5, sntp@1.0.9, boom@2.10.1, hoek@2.16.3)
├── http-signature@1.1.1 (assert-plus@0.2.0, jsprim@1.4.1, sshpk@1.14.2)
└── form-data@1.0.1 (async@2.6.1)
npm WARN package.json babel-traverse@6.11.4 No description
nodeunit@0.9.5 usr/pbi/mineos-amd64/share/mineos/mineos-node/node_modules/nodeunit
└── tap@7.1.2 (os-homedir@1.0.1, clean-yaml-object@0.1.0, opener@1.4.3, stack-utils@0.4.0, signal-exit@3.0.2, color-support@1.1.3, i
sexe@1.1.2, only-shallow@1.2.0, deeper@2.1.0, tmatch@2.0.1, tap-parser@2.2.3, readable-stream@2.3.6, glob@7.1.2, foreground-child@1.
5.6, tap-mocha-reporter@2.0.1, bluebird@3.5.1, js-yaml@3.12.0, coveralls@2.13.3, nyc@7.1.0)
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /npm-debug.log
npm ERR! not ok code 0
Is the error im getting after running service mineos ouneupdate. I tried updating node with pkg install noge and node -v even tells me i got version 10.4.1 but in the error log it says 0.10.31. Why is thins and how do I update?
gyp ERR! not ok
├── aws-sign2@0.6.0
├── caseless@0.11.0
├── isstream@0.1.2
├── aws4@1.7.0
├── extend@3.0.1
├── qs@6.2.3
npm ERR!
